Sealed Concrete - Painting - DIY Chatroom Home Improvement Forum
Old 03-08-2015, 03:26 PM   #1
Rewards Points: 249
Sealed concrete
I have a very smooth concrete floor on a screened in porch. The concrete was given a quick one coat sealer by the concrete Co. Not much of a sealer job. I want to paint over it with a light color epoxy paint or any paint made for outdoor concrete. My paint store is advising me to power wash the concrete first,& there could be a problem getting a paint or epoxy finish to bond to the concrete because of the sealer. Can someone tell me for sure that the original sealer could cause a problem. I don't think the original sealer job was of any real value. It was a quick spray applied using a pump up garden sprayer. Application took no more than ten minutes to do on a 14' x 18' concrete slab. The slab is now one year old & in excellent condition. The only concern is applying a solid color finish over the clear sealer. Thanks.
maddog1 is offline   Reply With Quote
Old 03-08-2015, 04:19 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
If the concrete has a sealer on it you will have to remove the sealer before applying your epoxy coating. Sealer can be removed through a mechanical method (usually grinding or blasting) or using chemical stripper. If the concrete floor is smooth it will also need to be etched (make the surface almost like 120 grit sandpaper), the surface should be cleaned using a detergent that will degrease it.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
maddog1 (03-08-2015)
Old 03-08-2015, 06:01 PM   #3
Rewards Points: 249
My paint store did mention chemical stripper as well as sanding it. I really don't think there is much left of the sealer. That is to say, there is no "Shine" on the surface of the concrete, but it's a real smooth finish. The concrete contractor finished it using rotary powered float to bring a real smooth finish. It looks real good. Wish they did not put on the sealer.
I moved out of lower Hudson Valley two years ago (orange county, Warwick town) All my life in NY. Got disgusted with the taxes, corruption, snow & ice. Retired & could no longer afford to live there. Things are a little easier here in South Carolina. Thanks.
Old 03-08-2015, 07:26 PM   #4
Rewards Points: 616
Test it. Pour some water in different areas and see if the water beads up. Depending on the sealer they used and other factors it may be worn off. If applying an epoxy or other coating you still need to clean it well and you should etch the concrete to a consistency of about 120 grit sandpaper for bite. You can buy concrete etching solution at Sherwin Williams, probably other places too.
By the way I understand what you mean about NY.
Old 03-08-2015, 07:52 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
Anything short of diamond grinding would be quite risky in your situation. Even if the sealer is mostly worn off it could easily cause adhesion problems. Also, as mentioned epoxy coating require a rough surface profile to adhere. Unless the concrete has a rough profile already, acid etching is highly unlikely to sufficiently etch the surface. The fact that its been sealed at all also reduces the chance of successful acid etching because the acid has no effect on the sealer.
If you want to do it right and not worry about a flaking disaster, grind the floor. You can usually rent floor grinders (not the same machine used on wood floors) at Sherwin Williams or any large rental yard. It's not hard to do, it just takes time.
Jmayspaint is online now   Reply With Quote
Old 03-08-2015, 08:22 PM   #6
Rewards Points: 616
If you have a concrete floor with no sealer on it acid etching using the correct acid will etch the floor to a suitable profile for epoxy. You are correct that acid etching will not generally remove sealer.
Old 03-08-2015, 08:29 PM   #7
Rewards Points: 249
Thanks- I will try tat water bead test. Lots of good advice here. I'm sure it will have a happy ending.
Are my concrete piers doomed to fail? Pharm80 Concrete, Stone & Masonry 6 09-11-2014 01:03 PM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
