Scuffing Semi Gloss On Orange Peel Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 06-05-2013, 12:44 AM   #1
Rewards Points: 452
scuffing semi gloss on orange peel drywall
sanding semi gloss paint on orange peel texture only scuffs the high points.
The low points are still glossy. Basically, you're only able to scuff half the surface area.
I've washed the wall with Simple Green, which does not remove gloss.
When putting on another layer of semigloss, will this have adhesion problems?
pman6 is offline   Reply With Quote
Old 06-05-2013, 04:00 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 616
Wash with Dirtex you should be fine. What and why are you painting semi gloss on?
Old 06-06-2013, 04:03 AM   #3
Rewards Points: 452
walls in a rental house. because dirt can be washed easily.
Old 06-06-2013, 07:50 AM   #4
Jmayspaint's Avatar
Rewards Points: 536
As long as your going latex over latex it will be fine. Just clean it good
Jmayspaint is online now   Reply With Quote
Orange Peel Texture Help please kalaniwavo Painting 12 07-13-2015 02:48 PM
smoothing out old gooey semi gloss paint leatrice gulbra Painting 3 02-03-2012 03:08 PM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
Same Ceiling: orange peel and knockdown sir_rob Painting 17 10-01-2007 04:28 PM
Knockdown ceiling : My walls are orange peel.. Arkanoid Remodeling 4 08-07-2007 12:23 PM
