-   -   scuffing semi gloss on orange peel drywall (http://www.diychatroom.com/f4/scuffing-semi-gloss-orange-peel-drywall-181310/)
pman6 06-05-2013 12:44 AM
sanding semi gloss paint on orange peel texture only scuffs the high points.
The low points are still glossy. Basically, you're only able to scuff half the surface area.
I've washed the wall with Simple Green, which does not remove gloss.
When putting on another layer of semigloss, will this have adhesion problems?
chrisn 06-05-2013 04:00 AM
1 Attachment(s)
Wash with Dirtex you should be fine. What and why are you painting semi gloss on?
pman6 06-06-2013 04:03 AM
walls in a rental house. because dirt can be washed easily.
Jmayspaint 06-06-2013 07:50 AM
As long as your going latex over latex it will be fine. Just clean it good
