Scraping Chipping Paint From A Brick Wall. Suggestions? - Painting - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 05:07 PM   #1
Scraping chipping paint from a brick wall. Suggestions?
We are starting work on painting the house and have some questions. What is the best way to get rid of the chipping, and more importantly, painted over chips, as seen in the pictures below. If you see how the neighboring blue house has nice smooth bricks, but my house has bricks where you can see the old paint layer painted over.
Any suggestions appreciated. I would imaging there should be an attachment I can get for some of my power tools that can be used to scrape/polish without scratching the surface of the bricks too much.
smikhailov is offline   Reply With Quote
Old 07-19-2009, 10:17 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
When paint peels in layers, that means it didn't adhere and it could mean cheap paint or possibly a dirty surface that wasn't cleaned or that the first layer of paint has chalked and made the top layes fail. I would power wash it first, then scrape any remaining loose paint and then determine if the surfaces where the paint was peeled is sound or not.
Old 07-20-2009, 11:45 AM   #3
NAV
Yea, best way is to power wash with 3,000 psi or higher using an osculating tip. hand tool the rest.
NAV is offline   Reply With Quote
Old 07-20-2009, 05:33 PM   #4
LeviDIY's Avatar
Rewards Points: 252
Would a sandblaster work as well?
LeviDIY is offline   Reply With Quote
Old 07-20-2009, 05:58 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
Pretty hard on the brick and mortar I would think.
Old 07-21-2009, 11:48 AM   #6
NAV
sandblasting would work great if you want to spend up to $4 per square foot. if the mortar is in bad shape it can damage it but if it is sound you should be fine.
If you blast it I would recommend not painting it again.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Old Paint Chipping Off daveofnj Painting 5 10-06-2007 09:29 AM
