Scraped Popcorn - Any Tips Before I Texture? - Painting - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 07:48 PM   #1
scraped popcorn - any tips before i texture?
so i've scraped a bunch of popcorn and am getting ready to texture. the taped seams look good and flat and there's hardly any damage to repair.
what type of primer should i use? do i prime the ceiling first then texture, or texture first then prime?
any tips would be great!
thanks!
norcalsurfer1977 is offline   Reply With Quote
Old 01-11-2009, 12:24 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I am assuming you are refering to texture paint. There are 2 reasons why you should prime first. First is you get a more durable and even coverage. The second reason is that applying texture paint over an already primed surface will keep a wet edge longer and it is critical when applying a texture paint.
Old 01-11-2009, 11:02 AM   #3
Drywall contractor
Rewards Points: 1,070
Definitely prime first. Often there is residual dust after you scrape/sand and your new texture will not bond properly if the old surface isn't sealed.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-11-2009, 11:23 AM   #4
Rewards Points: 506
I would prime first after thoroughly vacuuming and tacking to remove sanding dust. If using popcorn (as opposed to texture paint), I would prime the texture itself after application.
SirWired
sirwired is offline   Reply With Quote
Old 01-11-2009, 12:00 PM   #5
no, i'm not going to use a texture paint. i'm going to do a knock down texture. any good primer you all recommend?
Old 01-11-2009, 03:25 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
Prime first
A quality primer from Benjamin Moore, Sherwin Williams, or Pittsburgh would be just great
slickshift is offline   Reply With Quote
Trends in 2009: POPCORN TEXTURE IS BACK! studiobarb Interior Decorating 11 09-02-2008 06:26 PM
Knock down application tips needed gmhut Painting 1 07-31-2008 09:30 PM
scraped the popcorn off the ceiling, and tore through the paper-now what chapito Painting 6 07-18-2008 10:17 PM
Removing painted popcorn texture from ceiling cnielsen4130 Remodeling 8 10-07-2007 11:21 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
