-   -   scraped popcorn - any tips before i texture? (http://www.diychatroom.com/f4/scraped-popcorn-any-tips-before-i-texture-35604/)
norcalsurfer1977 01-10-2009 07:48 PM
so i've scraped a bunch of popcorn and am getting ready to texture. the taped seams look good and flat and there's hardly any damage to repair.
what type of primer should i use? do i prime the ceiling first then texture, or texture first then prime?
any tips would be great!
thanks!
Matthewt1970 01-11-2009 12:24 AM
I am assuming you are refering to texture paint. There are 2 reasons why you should prime first. First is you get a more durable and even coverage. The second reason is that applying texture paint over an already primed surface will keep a wet edge longer and it is critical when applying a texture paint.
bjbatlanta 01-11-2009 11:02 AM
Definitely prime first. Often there is residual dust after you scrape/sand and your new texture will not bond properly if the old surface isn't sealed.
sirwired 01-11-2009 11:23 AM
I would prime first after thoroughly vacuuming and tacking to remove sanding dust. If using popcorn (as opposed to texture paint), I would prime the texture itself after application.
SirWired
norcalsurfer1977 01-11-2009 12:00 PM
no, i'm not going to use a texture paint. i'm going to do a knock down texture. any good primer you all recommend?
slickshift 01-11-2009 03:25 PM
Prime first
A quality primer from Benjamin Moore, Sherwin Williams, or Pittsburgh would be just great
