Scrape Cracks, Compound, Sand, Paint. Question About The Sanding Step. - Painting - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 05:20 PM   #1
Rewards Points: 121
Scrape Cracks, Compound, Sand, Paint. Question about the sanding step.
I have a ceiling that was skim coated about 10 years ago. It was skim coated b/c the paint was 20 years old and chipping EVERYWHERE. To repair/sand/feather it would have taken months. Instead, if was skim coated in 2 days. It's holding up decently, but there are a few cracks where shower moisture has reached.
So, I blasted out all cracks with a putty knife. I applied joint compound. I did not try to make a perfectly smooth finish since I knew I'd be sanding it either way. I waited about an hour and applied a 2nd coat of compound to make sure the entire patch was "raised" for sanding (and not below the plane of the rest of ceiling) and to fill in some air holes.
The next day, I sanded with 200 grit on a sanding block. Pretty close. I then feathered some spots with some sandpaper around my finger. I think it's ready for painting (2 coats)
1) Does it seem like I am doing this the right way?
2) I just read the joint compound directions on the can.
It said not to dry sand but to "sand" using a damp sponge!
Much less dust. Is this what most people do?
Mathlete is offline   Reply With Quote
Old 08-15-2012, 05:26 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Personally, no. I don't think a sponge feathers good at all and because it is soft it will leave a hump.
I use ( depending on mud, there are many types/hardnesses) a hand sander with 100- 150 grit. But if you have a quantity to do , there are ones that can attach to a vac to suck up the dust as it goes.
Marshalltown makes the best one i know of, and is best to find online.
Other than that- just lay drops and be ready for a little dust to clean up.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-15-2012, 05:29 PM   #3
Rewards Points: 121
Thanks, I will stick to 150 grit, but what do you mean by "laying drops"?
Old 08-15-2012, 05:35 PM   #4
Dropcloths- cover what you dont want covered with dust.
Old 08-15-2012, 05:37 PM   #5
Rewards Points: 121
Just wondering, what about wetsanding with that black waterproof sandpaper (like you'd use on plastic headlights)
Do people ever do that?
Old 08-15-2012, 05:50 PM   #6
If it is premixed- I think it rewets too easy- if it was setting mud ( powdered- hardens chemically ,not by evaporation) and the abrasive was on a handsander so it didn't ride up and over ( hump) maybe.
But if your just doing a small area, and not finishing with anything glossy it might not be a problem.
Make sure to spot prime after you are done ( or hit it with the paint to prime if acrylic)
Old 08-15-2012, 05:54 PM   #7
Rewards Points: 121
What will the primer do?
Help fill/mask imperfections?
Old 08-15-2012, 06:01 PM   #8
Learning Things Every Day
Jay 78's Avatar
You absolutely have to prime over the areas where you used the compound. Attempting to paint directly over those areas is going to pick up and drag/dust, and the paint will suck right into the compound and 'flash'. You need to seal it with primer before painting.
Under Construction
Jay 78 is offline   Reply With Quote
Old 08-15-2012, 06:03 PM   #9
Rewards Points: 121
Got it. Thanks!
http://www.familyhandyman.com/DIY-Pr...View-All#step5
Old 08-16-2012, 06:03 AM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
give the paint something to stick too
chrisn is online now   Reply With Quote
Old 08-16-2012, 05:38 PM   #11
Rewards Points: 121
I painted the dozen or so repairs in made on my ceiling.
However, the new paint seems like a different color.
However, when I used the ORIGINAL can of leftover Eggshell paint,
it seems whiter than the ceiling. Is this b/c it's not cured yet?
How long until it starts to look like the original existing eggshell paint?
Unless I used the wrong paint, but I am almost positive this is how it was done originally:
Light Grey on the walls
Semi gloss in kitchen/bath/trim.
Eggshell white on ceiling.
Old 08-16-2012, 05:47 PM   #12
..did you prime the spots first?
Old 08-16-2012, 05:48 PM   #13
Rewards Points: 121
Yes, primed well.
Old 08-17-2012, 04:14 AM   #14
chrisn's Avatar
Rewards Points: 136
Again, are you using the term "eggshell" as a color or a sheen?
Old 08-17-2012, 08:52 AM   #15
Rewards Points: 121
Benjamin Moore
Eggshell Aquavelvet
Super White 319 02
It's the next day, and the paint does not match.
The old original ceiling looks grey/white.
But, the touch ups looks like cream/beige
Either the ceiling faded big time,
or the paint can got "stale" and turned beige,
or I did not mix the old paint can enough.
I will go buy a new can of "Super White 319 02"
and try touching up with a new (fully mixed can)
and see how it compared.
Does this seem like the right plan?
oak floor sanding question adjason Flooring 3 06-18-2009 09:09 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Sanding my stairs. Wrong equipment? Question about removing treads. Kinda long, sorry Mike in Arkansas Flooring 3 04-23-2009 02:04 PM
Parquet - sanding and refinishing question BradG Flooring 5 02-05-2008 12:12 PM
joint compound question golfer General DIY Discussions 3 01-09-2006 07:19 AM
