Saving A Paint Brush - Painting - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 12:46 AM   #1
Rewards Points: 77
Saving a paint brush
My wife used a $12 paint brush for a project of hers, didn't clean the brush and now it completely rigid. She used a latex paint, is there any way to save the brush without having to reinvest in another? The brush has nylon bristles.
Justins1171 is offline   Reply With Quote
Old 01-08-2012, 01:08 AM   #2
Rewards Points: 526
I would put the brush in water up to the ferule for a day or two and see what happens. It is toast as a good cutting brush, but you may be able to rehabilitate for use as a dust brush.
Windows is offline   Reply With Quote
Old 01-08-2012, 01:26 AM   #3
Rewards Points: 558
Been there done that. Get yourself a pail, add some warm water and add some dish soap in it. Next thread a coat hanger wire through the hole in the handle of the paintbrush and lay the coat hanger wire across the mouth of the pail so the paintbrush is suspended in the soapy water. The liquid should cover the brush bristles while the coat hanger prevents the bristles from touching the bottom of the pail. Leave the hardened brush to soak for at least 30 minutes then remove the brush from the soapy water. Run the brush under warm water in a sink and clean out the paint by spreading the bristles apart with your fingers then comb out the excess paint over the sink using a wire paint comb. Rinse the brush under the tap until water runs clear, shake out any excess water and hang the brush up to dry.
epson is offline   Reply With Quote
Old 01-08-2012, 07:57 AM   #4
To cut to the chase Justin, the brush is toast. I'll split the difference between Epson and Windows. Epson, if sudsy water was an effective solvent, my painter whites would be white, not latex paint spattered. And windows is correct that it may be slavageable as a duster, or a primer brush at most. To effectively remove dried latex paint would require a solvent like brush cleaner or denatured alcohol, which will run about 10 bucks a quart, and then at least a half hour or more of your time. And even then, there will still be residual paint inside the bristles which will dislodge as your working and deposit in your finish. Trust me, I've tried this many times in many ways, and I finally realized it was costing me more to restore a brush, that was never fully restored, than it was to buy a new one. It's simple economics. I occassionally find one that sat out overnight, it usually goes right in the trash.
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
Jay 78 (01-08-2012), ltd (01-08-2012)
Old 01-08-2012, 09:44 AM   #5
Gymschu's Avatar
Rewards Points: 512
It's done.......there are lots of brush rehab liquid formulas out there, but, in the end, they not only remove the dried paint, they destroy the bristles. Lesson learned.
Gymschu is online now   Reply With Quote
Old 01-08-2012, 10:56 AM   #6
jschaben
Rewards Points: 502
50-50 mix of ammonia and water. Immerse just up to the ferrule. allow to soak overnite. wash with warm water and dish liquid. see what ya got. I've everything from good luck to no luck but you haven't anything to loose at this point.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
Gymschu (01-08-2012)
Old 01-08-2012, 12:21 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
It's toast. Even with brush cleaner they never really come back to normal.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Old 01-08-2012, 06:00 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
I don't know about "toast"( I like toast) but as a paint brush it is worthless
chrisn is online now   Reply With Quote
Old 01-08-2012, 07:06 PM   #9
Good thing it was a cheap brush to begin with.
mudbone is offline   Reply With Quote
Old 01-08-2012, 11:16 PM   #10
Learning Things Every Day
Jay 78's Avatar
You can save it. Use it to baste a turkey for your in-laws next Thanksgiving.
Under Construction
Jay 78 is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
behr paint and brush? Enevarez Painting 21 12-05-2011 08:35 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 02:24 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
