Satin Versus Flat Paint - Painting - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 05:42 PM   #1
satin versus flat paint
I have a bedroom and attached bath i'm going to paint...should i use a satin or flat paint?
wuber is offline   Reply With Quote
Old 08-24-2012, 06:01 PM   #2
Rewards Points: 150
I would go with eggshell finish and not flat for washable reasons. No Flat in the bathroom!
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-24-2012, 06:52 PM   #3
Rewards Points: 13,994
Flat will show every hand print, very hard to clean. The glossyer the better on bathroom walls.
The ceiling should be flat to show less flaws.
Old 08-25-2012, 08:23 AM   #4
Too Short? Cut it Again!
Joe I wish you would stop with this advice. Good quality flat is no harder to clean than anything else. Client's kids have taken their dirty, slimy hands to Aura flat since it came out and cleaning has never been a problem. And gloss isn't always better for bathroom walls. And if it is better for the walls it is better for the ceiling too.
You may paint these rooms any sheen you want. The higher the sheen the more surface defects will show. Going to a semi-gloss in a small enclosed, steamy bath may be a good idea for the ability to wipe it down if the walls stay moist and build up algae. If there is adequate ventilation a satin or certainly an eggshell will do as well. Semi-gloss baths tend to look a little institutional also.
And you may paint the ceiling with any sheen you want also. And it doesn't have to be white.
Old 08-25-2012, 09:23 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
Sds and Joe- I'm going to sit in the middle on this one.
I do think some sheen is good for a bath with humidity. Although most flats are not true flats ( like a ceiling paint) and have some wash, they still let moisture penetrate more.
I almost always recommend an eggshell for baths.
And wuber- realize that different co call the sheens different things.
For instance a satin in BM is higher than an eggshell, in SW it is lower.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-25-2012, 10:57 AM   #6
Wasn't trying to start a battle or force people to draw sides or hide in the middle.
I certainly would prefer something other than flat for a bath. I have painted flat in a bath though and can think of one in a very expensive situation where that is what the client wanted. It is holding up just fine but has plenty of ventilation and does not get moist and soggy. I wouldn't walk away from painting with flat based on nonsense about it not being washable.
Old 08-25-2012, 04:35 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 492
[quote=sdsester;996012]Wasn't trying to start a battle or force people to draw sides or hide in the middle.
I certainly would prefer something other than flat for a bath. I have painted flat in a bath though and can think of one in a very expensive situation where that is what the client wanted. It is holding up just fine but has plenty of ventilation and does not get moist and soggy. I wouldn't walk away from painting with flat based on nonsense about it not being washable.[/quote]
As you have said, todays QUALITY flats are and have been wasable. The problem lies in it means a trip to a real paint store and not the local big box.
Old 08-27-2012, 12:53 PM   #8
Rewards Points: 394
True- most premium flats have good solids and a slight angular sheen to them (some up to 10 units @85 degrees). This makes them washable, not necessarily scrubbable. In a high humidity environment, a higher sheen may be preferable.
Will22 is offline   Reply With Quote
Old 08-27-2012, 01:48 PM   #9
Is the matte in aura more washable than the matte (or equivalent) in regal select, in your experience? Trying to decide if its worth the $$$. Definitely don't want anything shiny on my plaster walls, which will probably be even more flawed after I'm done with them. heh.
MEE123 is offline   Reply With Quote
Old 08-27-2012, 03:45 PM   #10
Yes, that is one of Auras selling points. But know that no paint is fully washable before fully cured, 2-4 weeks depending on what, humidity etc.
Old 08-29-2012, 02:30 PM   #11
Bombastic Idiot
notmrjohn's Avatar
I'm gonna sit off to the side and watch um duke it out with roller and brush, no putty knives or spray guns, boys. You could get hurt sitting in the middle.
And just my non-pro opinion, while good flat can be as easy to clean as glossier, it just seems to show "dirt" quicker. On the other hand ( I can be a messy painter and get paint on both hands,) glossier shows surface imperfections more. One armed paper hangers only get one opinion.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 08-29-2012, 04:23 PM   #12
chrisn's Avatar
Rewards Points: 492
watch it
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Painting over flat paint in bathroom lewisj Painting 2 03-17-2009 04:12 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
