Satin Or Semi-Gloss Paint For Molding And Trim? - Painting - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 10:26 AM   #1
Satin or Semi-Gloss Paint for Molding and Trim?
I'm re-doing all of the trim in my house. The old trim was small, simple, and stained. I'm going with a more decorative and larger trim and will be painting it white. Which sheen of paint should I use, satin or semi-gloss?
thanks!
tdeepness is offline   Reply With Quote
Old 03-27-2010, 12:38 PM   #2
Semi-gloss is the typical sheen on painted trim. Potentical buyers might expect it.
But, style of trim, age of house, and general impact of the space can all be considerations to look at other sheens that might work better or make a statement.
Don't be afraid to test an area or a room if you feel like trying something.
Big Bob is offline   Reply With Quote
The Following User Says Thank You to Big Bob For This Useful Post:
tdeepness (03-27-2010)
Old 03-27-2010, 01:14 PM   #3
water flows downhill
oarfish's Avatar
Usually this is how goes from flat to shiny: flat, satin, semi gloss, high gloss.
Some brands: Flat, eggshell, satin, gloss.
What I am trying to say is the satin and semi gloss could have the same amount of sheen depending on brand.
I would use either one with confidence on woodwork.
oarfish is offline   Reply With Quote
The Following User Says Thank You to oarfish For This Useful Post:
Old 03-28-2010, 07:45 AM   #4
I've painted a bunch of trim with Muralo Satin flow enamel and I really like the subdued look.
slickracer is offline   Reply With Quote
The Following User Says Thank You to slickracer For This Useful Post:
tdeepness (03-28-2010)
Old 03-29-2010, 08:59 PM   #5
I use
I use Muralo Ultra waterborne semi Gloss-the best trim paint I've ever used
CommerceComet is offline   Reply With Quote
The Following User Says Thank You to CommerceComet For This Useful Post:
tdeepness (03-30-2010)
painting trim with semi gloss paint sninny Painting 10 09-21-2012 04:33 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
