Sap Coming Up Thru 2 Coats Of Wood Stain? - Painting - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 06:19 PM   #1
Sap coming up thru 2 coats of wood stain?
I had stripped the deck and covered with 1 coat of SW latex solid color stain.
It sat for 30 days and we decided to change color.
light power washed it and came over with second coat of same stuff, different color.
Made sure it was completely dry before staining.
After about 2 weeks, I noticed a sticky substance coming up on deck?
Never saw anything after the first coat.
Some of it is brown and sticky and definitely sap.
Other spots it is white and chalky, but still sticky.
We have had really bad humidity here, but I've never heard of sap coming up thru 2 coats?
Not sure what to do?
Stain still looks okay and is not peeling or chipping.
Anyone seen or heard of this?
gitnby is offline   Reply With Quote
Old 08-14-2010, 11:50 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Latex products won't stop sap bleed. Even oil has a hard time blocking it out. You can try a clear shellac just on the knots and then recoat with the stain.
Are you sure it is coming out of the deck and not from above?
The white substance sounds more like chemical bleed. How old is this deck?
poppameth is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Bullseye 1-2-3 or Cover Stain for bare interior wood? cej22 Painting 5 07-09-2009 04:09 AM
How to pick a wood stain? integlikewhoa Flooring 2 06-15-2009 10:50 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Help wood stain showing through paint laviticus Painting 6 03-18-2006 12:35 AM
