Sanding Vs Liquid Sander For High Gloss - Painting - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 10:51 AM   #1
sanding vs liquid sander for high gloss
Newbie here-
Husband and I are in the process of purchasing our first house and almost the entire interior is painted with this God awful color and it's high gloss (I am assuming latex) paint. The kicker is they just recently did this; I really wish they hadn't.
This house is pretty big and has the two story foyer entrance, so I know the task before us is not an easy one. The existing paint has a slight granuled textue to it, so as far as sanding goes....does liquid sanding work as well as regular sanding? Should we sand and use liquid sander before priming and painting?
Thanks is advance!
egzh is offline   Reply With Quote
Old 06-24-2009, 03:31 PM   #2
NAV
if it is latex interior walls and the texture prevents sanding i would recommend neither.
Buy Sherwin-Williams PrepRite Bonding primer. one coat of that and your set to paint.
good luck
NAV is offline   Reply With Quote
Old 06-24-2009, 11:01 PM   #3
100 Year Family Tradition
4ThGeneration's Avatar
The problem with liquid sandpaper is that you have a very short window to prime after you clean.
4ThGeneration is offline   Reply With Quote
Old 06-25-2009, 04:26 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Do NOT assume ,make sure before proceeding. It sounds like they were in a hurry to cover up something and could have painted latex over oil( a bad thing).
Sanding is always better than liquid deglosser.As Nav said maybe all you need is a good bonding primer, but then again you may have a complete disaster on your hands( I have seen this many times)
Good luck
chrisn is online now   Reply With Quote
Old 06-25-2009, 07:58 AM   #5
Good luck
Oh yes, we will absolutely make sure as soon as we get the keys
Fingers crossed for just the bonding primer!
Old 06-25-2009, 06:59 PM   #6
chrisn's Avatar
Rewards Points: 614
Sanding drywall using a power sander? gone_fishing Remodeling 3 03-14-2009 07:20 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 09:44 PM
