Sanding Varnished Door Frames...what Grit? - Painting - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 04:57 PM   #1
Rewards Points: 150
Sanding varnished door frames...what grit?
I'm about to replace baseboard, doors, etc. I'm keeping several of the door frames, which are varnished. I have a 5" R.O. sander. What grit count(s) should I use to get the best results? Any pointers or warnings also appreciated.
Also, afterwards...1 coat primer then a good semi-gloss paint?
Thanks!
rightit is offline   Reply With Quote
Old 12-08-2012, 05:25 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
If you're prepping them to prime/ paint them, i wouldnt use the power sander. All you need to do is dull the finish enough so that the primer has something to grab on to. And you don't want sanding scratches to show through. 150- 220 would work fine- i would use a sponge with fine grit.
Use a bonding primer- I'm liking Zinnser 123+ ( same as Smart Prime) , or reg 123
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
rightit (12-08-2012)
Old 12-08-2012, 05:56 PM   #3
Rewards Points: 150
Thanks!
Scrape Cracks, Compound, Sand, Paint. Question about the sanding step. Mathlete Painting 18 08-19-2012 04:15 PM
Oak cabinet does not stain after sanding samotlietuvis Painting 1 10-12-2011 11:33 PM
Sanding Hardwood floor tips dzobrist Flooring 11 09-21-2011 04:27 AM
Car Painting and sanding h3llfir3 Painting 19 08-11-2009 09:44 PM
Sanding my stairs. Wrong equipment? Question about removing treads. Kinda long, sorry Mike in Arkansas Flooring 3 04-23-2009 01:04 PM
