Sanding Trim - Painting - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 08:49 AM   #1
Rewards Points: 2,072
sanding trim
hi,
Do I sand the trim in between the 2 coats of semi-glossy paint?
thanks
Startingover is offline   Reply With Quote
Old 06-19-2012, 11:08 AM   #2
Mr. Paint's Avatar
Sanding isn't necessary between uncured coats. If your next coat is applied weeks later, it would be advised. Follow the recoat directions on the paint can label.
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
Startingover (06-19-2012)
Old 06-19-2012, 11:42 AM   #3
Rewards Points: 13,296
Depending on the style of trim I often use a 4" hot dog style foam roller when priming and painting. This way there's no brush marks and it's faster.
I also presand all my trim. Most unprimed trim will have what's called mill marks on it. It looks like horizontal lines on the face caused from the planner.
A real quick sanding with about 100 grit paper takes it right off.
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 11:29 PM
Easiest way to paint/finish baseboard/window/door trim in entire house? Michael-stl Painting 6 02-25-2012 10:30 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Speed up sanding for window and door trim Karde Carpentry 3 08-23-2009 02:01 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
