sanding stipple on smooth walls?
Burn coats?
About paper- the paint will be harder than the mud, so it won't scratch so easy. I usually will take 2 pieces of the paper and rub then together to make them a little less aggressive
Recoat time is on can-- do not need full cure.
Technique is as important to small stipple as is roller nap. Also quality roller vs cheapo.
I almost always use a 1/2, wooster super fab or Purty white dove.
First stroke applies paint about 1 1/2 width of roller, then a couple of strokes to spread that out even, then finish long even stroke ceil to floor to finish. Sometimes I will do about a 4' section in the put on spread mode and then fall back and do most of it with the finish stroke. That gives the paint a little time to settle and makes for smaller stipple. But you must make sure that it is still wet and not stetting up. That will cause sheen differences..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
