Having the house we just moved into professionally painted next month. The people that had the house previously spackled the zillion holes leaving spackle marks from 1 inch round to 5 inches round. Then they painted over this crappy job. The spackle job is so bad that the edges of the spackle is probably 1/16 to a 1/32 thick. Whats the best way to remedy?...sand the hell out of it through the paint?...rent commercial wall sander?...any advice greatly appreciated.
I'm wondering why you are wanting to try to fix this problem yourself if your having it painted next month. An experienced painter could take care of that problem during the general prep work for the paint job.
The spackle spots being painted over complicates the problem, but they can still be sanded out. It will likely take some additional patching after sanding to totally blend the spots in.
I would advise you to talk to your painting contractor before doing anything to the spots.
thanks...my painter said that he has never seen this kind of ridiculousness. There are literally 12 to 15 3-4 inch patches on almost every wall. Like a 7 year old had a field day with a bb gun. He said that I can do it myself to save some cash, and that he is swamped so if his guys do it, the project has to be put off for several weeks. Is a random orbital the same as a palm sander (sorry for stupid question).
Palm sander makes me think of a vibrating sander which is not the same as a random orbital. A random orbital fits in your palm and could be called a 'palm' sander, but it spins as opposed to vibrates. You could use a vibrating sander, it would just be way slower.
Palm sander makes me think of a vibrating sander which is not the same as a random orbital. A random orbital fits in your palm and could be called a 'palm' sander, but it spins as opposed to vibrates. You could use a vibrating sander, it would just be way slower.[/QUOTE]
80 or 100 grit would speed it up some:laughing:
120- 220 is not enough grit to get through the paint and spackle(IMO)
I also like coarser grit (80) for getting down paint. You should give it a light coating of compound after sanding to smooth it out. You can then sand that with 150 before painting.
OK..I'm back. The random orbit sander worked like a champ. Went with a Rigid that I bought from HD after reading a bunch of reviews on line. Went through about 8-10 discs 100 grit. It made short work of the spackle that was left...thanks for the advice..also have a review of the paint sprayer that I rented, but will post that in the paint area.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
