Sanding Primer Woes - Painting - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 08:52 PM   #1
Arrow
Sanding Primer Woes
I built a study desk out of 3/4 MDF unprimed. Craftsman style.
Blew it off, wiped it down, ample dry time.
I primed it W/ Zinsser Plus water base. Let Dry 3 days.
Attempting to block sand w/ 100Gr paper, the primer is rolling or balling, not turning to a nice dust. Ambient temp was ok. Humidity ok. I had this issue once B4 but can't recall the remedy. Please help!
BZWAK is offline   Reply With Quote
Old 10-14-2011, 10:24 PM   #2
Painting Contractor
Rewards Points: 87
There are specific primers made as enamel undercoats which are designed to sand and powder out. Sounds like your primer was more of a general purpose primer, and latex tends to sand just as you suggested. At this point re-prime with an enamel undercoat, and is should sand well.
kkeith is offline   Reply With Quote
Old 10-14-2011, 11:45 PM   #3
You might try using a finer paper, like 150. 100 may be cutting too much.
The Following User Says Thank You to jsheridan For This Useful Post:
boman47k (10-15-2011)
Old 10-23-2011, 10:37 AM   #4
Thanks for the help! I switched to 120gr and a ROS. The tiny strokes I think is what produced dust rather than the balling.
Also, you are correct on the type of primer. Lesson learned, Thanks Again!
Old 10-23-2011, 11:16 AM   #5
By ROS, I think you mean an orbital sander of some type. But, it could be a Robot Operating System, a Reactive Oxygen Species, or a Return On Sales, according to Google. Since I don't think any of those would contribute to easier sanding, most especially the Robot Operating System, I'm assuming you meant some type of orbital sander. But, either way, I'm glad you solved your problem.
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 07:16 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Sanding After Primer RickyBobby Drywall & Plaster 2 05-26-2011 12:28 AM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 03:31 AM
Sanding Primer Bpawb Painting 4 03-27-2008 04:23 PM
