Sanding Primer - Painting - DIY Chatroom Home Improvement Forum
Old 03-26-2008, 10:35 PM   #1
Sanding Primer
What are the advantages of sanding interior latex primer on new drywall?
Bpawb is offline   Reply With Quote
Old 03-27-2008, 08:30 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Final coat ends up smoother and better adhering
Any boogers, lumpies, and fuzzies get smoothed out or knocked off
Gives the next coat some "tooth" to hang on longer
slickshift is offline   Reply With Quote
Old 03-27-2008, 08:53 AM   #3
Thanks slickshift,
Reason I ask is I am using a high build primer from SW w/ a 1/2" nap roller cover and the results looked pretty good (to me anyhow)
It has a textured look that is slightly more bumpy than just the normal paint roller texture.
And was wondering how y'all thought this would look after the final top coats where applied?
Old 03-27-2008, 02:38 PM   #4
Paint Contractor
A 3/8th inch nap is what you should be using. Sanding the primer will not do much but knock off any pieces of roller nap that may have gotten stuck in the primer while rolling. The only time sanding after priming is necessary is on new wood which will fir up or the grain will come out from the primer.
movado is offline   Reply With Quote
Old 03-27-2008, 04:23 PM   #5
slickshift's Avatar
Originally Posted by Bpawb
...And was wondering how y'all thought this would look after the final top coats where applied?
Pretty much a textured look that is slightly more bumpy than just the normal paint roller texture
Paint colors, it doesn't fill
...well, except for something like a high build primer, but that's a different animal
Interesting using a roller with that
It's really meant to be sprayed to "smooth out" a drywall finish
Interesting effect with the roller...cool that you are digging it
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
Zinsser Primer on Wood Veneered Furniture cupcake Painting 3 10-05-2007 03:07 PM
Primer peeled Project Girl Painting 10 08-26-2007 04:39 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
Dustelss Power Sanding Systems MasterStrokes Tools 14 10-12-2005 05:51 PM
