Sanding Primer ? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 02:53 PM   #16
Rewards Points: 512
the puke green ultralight came out when the ultralight drywall came out. i guess its suppose to be a new and improved finishing compound. i havent personally used it, i've picked up a bucket at the store and it is lighter but i havent heard that its much better and for $5 a buck i was told not to waste my time/money. i always use lafarge rapid coat much better then any sheetrock product but use what you know works for you.
princelake is offline   Reply With Quote
Old 12-23-2012, 08:53 AM   #17
Rewards Points: 236
i put on almost half the bucket yesterday. i had to wet it down a good bit. perhaps i had a dry batch, idk. but the water helped a lot. i am going to be sanding it today.
Fix'n it is offline   Reply With Quote
Old 12-24-2012, 08:03 AM   #18
Rewards Points: 236
this stuff is great ! sands way easier that regular JC. that saved my asss, as i had a lot more sanding than i though. this sanding chit is for the birds !
The Following User Says Thank You to Fix'n it For This Useful Post:
ToolSeeker (12-24-2012)
Old 12-24-2012, 08:11 AM   #19
Rubbin walls since'79
Brushjockey's Avatar
lol- everyone's' favorite job. I use a hand sander hooked to a shop vac- at least it makes it way less messy.
Sounds like you're getting it though. keep it up!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-24-2012, 08:26 AM   #20
Rewards Points: 236
man. my freak'n body is hurting me. and my house is a mess, kinda. but i got it mostly cleaned up. and i have the whole room primed. i do still have some fix'n to do. but i should be able to paint next weekend.
i did learn my lesson on putting up drywall = no more butt joints, ever. full sized sheets, no cutting of the tapered sides, 16" oc throughout , cut out for windows and doors = nothing but tapered joints = easy tap'n and sand'n.
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 06:16 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Sanding Primer Woes BZWAK Painting 4 10-23-2011 10:16 AM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 02:31 AM
Sanding Primer Bpawb Painting 4 03-27-2008 03:23 PM
