-   -   sanding primer ? (http://www.diychatroom.com/f4/sanding-primer-166942/)
Fix'n it 12-19-2012 09:04 PM
sanding primer ?
i am in the process of muding my new drywall. looks like i am not as good at it as i would like . so i know that there will be imperfections, even after i give it a good look over before primer. so, once i prime it, will i be able to sand down high spots ? i believe i will be able to put more mud on top of primer ? to fill low spots ?
i am focusing on one wall, so i can keep my errors in one place, and limit future errors.
Brushjockey 12-19-2012 09:46 PM
When you sand ( before priming), have a trouble light in your hand and hold it at an angle. When you do it you will see what I am saying- it will improve your sanding a billion percent.
After you prime, do the same with the light and touch up with mud where it needs it, repeat process, reprime.
With practice it will get better!
jsheridan 12-20-2012 05:21 AM
Fix, I'll add to BJ's always sage advice. Sanding is always a two handed job, one sanding and the other feeling for what needs to be sanded and for results your sanding is achieving.
It's always better to sand high spots out prior to priming, and it's better to spackle out low spots after priming or, if they're obviously low enough, before you prime.
Sanding out a high spot will break the "skin" of the primed surface and create a situation requiring a skim coat.
Using a light from the side will throw shadows and highlight imperfections on the surface.
Don't feel bad, after priming spackle touch up is pretty much expected and routine, even for the pros. Prep isn't finished until you're rolling the final coat on, and even then I've been known to knife some caulking or lightweight vinyl spackle, which can be painted over immediately, into picture holes or small dings while I'm finish coat rolling.
ToolSeeker 12-20-2012 07:27 AM
Knock off any ridges then using a 12" drywall knife put on a thin coat of Lightweight #3, or drywall topping mix, or the new ultra lite mud. Any of these 3 are a lot easier to sand than all purpose, and the 12" knife will feather your mud out farther and will help eliminate high spots.
princelake 12-20-2012 07:23 PM
if your work isnt as good as you would like then go over it again giving it a skim coat, there is no rule saying you can only do 3 coats. then do what brushjockey says.
Fix'n it 12-20-2012 08:27 PM
ok guys, thanx for the advice. i will try all of those things.
while i do not feel that all purpose is hard to sand. when there is a lot of sanding to do, anything that makes it go faster is a real help.
Fix'n it 12-22-2012 09:32 AM
2 Attachment(s)
i now have a bucket of SHEETROCK ultralightweight all purpose. . have yet to try it. probably today.
what a mess
ToolSeeker 12-22-2012 09:47 AM
Please let us know how it works for you I seem to be the only one that has tried it. Would be good to hear some one else's opinion.
Brushjockey 12-22-2012 09:53 AM
Rolling baker and the whole deal- you got it going on!
Brushjockey 12-22-2012 09:55 AM
The light green lid? What does it do that Plus3 doesn't ( blue lid)
Fix'n it 12-22-2012 10:01 AM
sure will.
wth is a rolling baker ? the scaffold ? i got that for $60 on CL = excellent buy :thumbsup:
chrisn 12-22-2012 10:33 AM
imo the blue is the way to go
Brushjockey 12-22-2012 10:37 AM
Yup- That is called a bakers scaffold- skinny and interior compared to the big square ones usually used on outside.
ToolSeeker 12-22-2012 01:02 PM
It's a lot lighter and easier to use you don't need to add water to loosen it up just stir. It's a lot easier to sand, it's almost like topping if you have ever used that.
Brushjockey 12-22-2012 01:30 PM
Plus 3 is about as soft and easy sanding as I'd want- I haven't seen that product- and will look for it.
Its all made by USG it looks like- so they wouldn't compete with themselves- must fit a need that I personally don't see yet- so I'll check it out when i can.
