Sanding And Painting Old Shed - Painting - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 05:35 PM   #1
Stephanie
Sanding and painting old shed
Hello,
I recently purchased a home, and the shed looks horrible! Super old, white, peeling/flaking paint. Do I need to fully sand the ENTIRE shed in order to paint it? Whats my best, least expensive option? Thank you!
steph13088 is offline   Reply With Quote
Old 03-06-2013, 05:36 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
What is it made out of? Wood, metal, vinyl?
hyunelan2 is offline   Reply With Quote
Old 03-06-2013, 05:43 PM   #3
Stephanie
I guess that would have helped to know. It's a very large, wood shed.
Old 03-06-2013, 05:44 PM   #4
Gymschu's Avatar
Rewards Points: 502
First off, you may want to check for lead. A lead-test kit is a good idea before you go scraping and sanding the shed. A good pressure wash to clean it up.......allow to dry. Scrape all the loose paint you can with a carbide scraper. If you're really fussy about the look of the shed, you can sand where you scraped to feather in the rough areas. Sanding ISN'T necessary but if you feel the need........anyway, once you're satisfied with the substrate after scraping/sanding, gently wash off any remaining dust and allow to dry. Then you can prime the bare spots with a quality exterior latex primer and apply 2 coats of quality latex paint.
Gymschu is online now   Reply With Quote
Old 03-06-2013, 05:57 PM   #5
cdaniels's Avatar
^^ yep
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Sanding and Painting Bob Guercio Painting 16 06-01-2012 06:36 AM
painting over exterior gloss & satin when sanding is difficult skiposwald Painting 1 09-24-2009 08:57 AM
Car Painting and sanding h3llfir3 Painting 19 08-11-2009 10:44 PM
Car Painting and sanding h3llfir3 Automotive Repairs 1 08-10-2009 11:02 PM
Sanding drywall after painting... argh! moneymgmt Painting 3 05-06-2008 08:25 AM
