Sanding Oil Based Enamel Between Coats. - Painting - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 10:38 PM   #1
Sanding oil based enamel between coats.
Help!
I recently painted a new hardboard (Masonite) door with two coats of Benjamin Moore oil based primer, so far so good, no sanding needed. After applying the first coat of BM Impervo low lustre oil enamel I got the bright idea to sand it with 120 before I applied the second coat, after I applied the second coat scratches from the sanding were showing through. Do I need to re-sand to remove both enamel coats (and scratches) with 220-320 to make it right, and start over with the enamel.
Darn,
-JH
user85116 is offline   Reply With Quote
Poly over WB enamel over sanding sealer? bobmg Painting 3 05-10-2010 07:59 PM
Oil based over Floor & Deck enamel RMCarner Painting 3 09-09-2009 07:08 PM
Is water based enamel permeable? nerd_flanders Painting 5 08-07-2009 08:54 AM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Sanding in between Varathane water based floor finish? Joony Flooring 1 07-09-2008 07:10 AM
