Sanding Drywall After Painting... Argh! - Painting - DIY Chatroom Home Improvement Forum
Old 05-05-2008, 08:40 AM   #1
Rewards Points: 262
Sanding drywall after painting... argh!
Yes, that's right; I say paint everything except this one wall, and they decide they didn't see why not, so they painted it anyhow. There is a horizontal drywall seam half way up the wall that hadn't been finished quite right so it needed another coat of compound and a good sanding. Now its been painted over and I'm trying to sand it which just ins't working. I can't leave this one seam unsanded, it looks absolutely terrible! Any words of advice?
moneymgmt is offline   Reply With Quote
Old 05-05-2008, 07:21 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Skim over with joint compound
Use a wide blade and try to at least "smooth out" the lumps
The repair areas will be higher than they would have been, but at least the over all appearance could get smoother
slickshift is offline   Reply With Quote
Old 05-05-2008, 07:36 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 890
What grit sand paper are you using?
Sir MixAlot is offline   Reply With Quote
Old 05-06-2008, 07:25 AM   #4
Rewards Points: 262
I'm using the medium grit pads. I tried 100 grit paper but it got jammed up with paint pretty quick and I didn't want to push so hard that it left gouges in the mud. I didn't think about mudding over the top of it and sanding from there; I'll try that, guess it can't hurt! Thanks all!
Painting new Drywall? sandyman720 Painting 10 02-23-2012 04:35 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
Removing drywall dust after sanding? ponchoman1 Painting 6 10-13-2006 07:33 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
