Sanding Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 12:39 PM   #1
Rewards Points: 83
Sanding Drywall
I just finished removing the popcorn from my ceiling and I'm so glad I did. I'm a long way off from the finished product but it looks so much better already. It only took an hour I did have one small knick. Thank goodness the builder did quality work with the ceiling it looks amazing underneath. How long do I have to let the drywall dry until I can sand?
ttwin is offline   Reply With Quote
Old 01-23-2013, 12:43 PM   #2
Rewards Points: 4,792
Um, you know you shouldn't be sanding the actual drywall right? If you've removed the popcorn, you should see white/gray drywall paper. You don't want to be sanding that.
Are you going to be putting another coat of joint compound on it?
jeffnc is offline   Reply With Quote
Old 01-23-2013, 12:47 PM   #3
Rewards Points: 83
No no that's what I meant, the drywall paper. No I'm going to fix the knick, sand with a fine sandpaper just to get the dust off and then prime and paint.
Old 01-23-2013, 01:00 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Your plan is fine- I would give it a quick sand myself. I think jeff was referring to a hard sand that would cut into the paper.
As far as dry- hard to answer- depends how wet you got it. If it feels dry, it probably is. if the mud gums up your sander- it's not.
Put a fan on it to speed it up if you want.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-23-2013, 01:05 PM   #5
Sure, after you patch, you can sand that. Sanding the drywall paper around the edges as a coincidence is fine, just don't go sanding your entire ceiling where just the paper is, that's all. No need and can't help, if done too much it can only make your final paint job look rougher.
Old 01-23-2013, 01:11 PM   #6
Rewards Points: 83
Thanks for the advice guys.
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Sanding drywall using a power sander? gone_fishing Remodeling 3 03-14-2009 08:20 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Furnace Issue After Sanding Drywall libero99 Drywall & Plaster 8 01-10-2009 10:08 PM
Sanding a drywall ceiling? kcrossley2 Drywall & Plaster 7 01-01-2009 10:44 PM
