Old 07-27-2005, 08:26 AM   #1
Sandblasting...sand, sand everywhere!
I just had my home sandblasted as part of the stucco prep for painting. I came home and there is sand everywhere! What would be a normal amount of residual sand left from the blasting? There is over 4-5 inches in all of my flowerbeds and in my grass. I know that silica dust is very harmful, and now I have concerns about dry-sweeping or blowing w/air compressor. Doesn't the sandblasting company normally remove most of the sand? Any suggestions will be greatly appreciated.
Glittergoddesss is offline   Reply With Quote
Old 07-28-2005, 11:47 PM   #2
Contractor
It sounds like a normal amount of sand. What will happen with it should be spelled out in your contract with the painters/sandblasters. Silica is one of the most common elements on the planet, certain forms can be dangerous, most are benign. I would be much more concerned about the paint that was removed.
What lead you to this form of paint removal? It is very rare around here.
Teetorbilt is offline   Reply With Quote
More On This Topic
There’s lots of different ways you can finish your straw bales. There’s plasters, there’s different types of cement stucco finishes, and I’m going to read you a couple of different mixtures of the cement stuccos. One is your... Read More »
Bronze is often used for metal sculptures. There are several processes a sculptor can use to build a bronze sculpture, including the lost-wax method, sandcasting and centrifugal casting. Among these, the lost-wax method, discovered in China, is the... Read More »
If you are working on a hot rod or any other vehicle and have the need to cut a glass windshield, you are in for a tough go at it. Cutting a glass windshield is very challenging and often produces results that are far from perfect. Even professional... Read More »
Now we need to prep the bales which really means cleaning them up for the stucco so that they’re flat or the shape that we want them to be. And the best way to do this with straw, believe it or not, one of our favorite tools is a weed wacker or a... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. What I would do with this exterior is stucco. I have stucco before which is just a mixture of water and cement pour in cement and sand and you just put it on there. I understand... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
