Old 01-24-2013, 07:35 AM   #1
sand and then paint out door shed
what is best way to sand out door shed, can you use the
pressure spray?
Brenda Casey is offline   Reply With Quote
Old 01-24-2013, 08:13 AM   #2
Gymschu's Avatar
Well, if it's a wood door just sand it a bit and then clean any dirt, mildew, dust off with warm water and repaint. No need for a pressure washer.
Oops, mis-read the post......an outdoor shed it is! Yes you can gently pressure wash an outdoor shed. No need for much more than 1600 psi to clean off all the gunk. Keep a stiff brush and some warm water with Krud Kutter in it for stubborn spots.
Old 01-24-2013, 08:17 AM   #3
Got a picture so the guys can see how bad it is?
Pressure washer used on wood can be a very bad thing done wrong.
