Old 09-01-2005, 11:26 AM   #1
To sand or not to sand
Hi all. New kid here. I'm building a picnic table and I've sanded down the planks real nice, filled in the voids and I'm ready to paint. I intend to put numerous coats of polyurethane with a UV blocker on the wood. Here's the question. After each coat dries, do I need to scuff up the surface with some sandpaper before the next coat, or am I OK to just put 'em on one after the other? It's hi-gloss.
Thanks in advance,
Rich
rich_from_mich is offline   Reply With Quote
Old 09-01-2005, 11:47 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Usually a light sanding with a 220 is the proper procedure
You may be able to "get away with" not doing it, but I wouldn't recommend it
slickshift is offline   Reply With Quote
Old 09-01-2005, 11:52 AM   #3
No sense putting $20 urethane on $8 wood and not doing it the right way. Thanks for the advice.
Rich
Old 05-22-2006, 07:30 PM   #4
Painting Contractor
Always sand in between coats of poly. I recommend 320 grit...the results are smoother than 220. Also, before starting your projects, wait for a few replies on here, dont just listen to 1 or 2...wait a little.
Paintguy26 is offline   Reply With Quote
Old 05-22-2006, 08:14 PM   #5
Remodeler
MinConst's Avatar
When doing fine finishes with poly I use a 220 or higher on the first coat, then just a scotch pad on the rest. If you can keep the majority of the dust off the finish while it dries, a scotch pad should do well. Just knock off the gloss.
It really sounds like over kill for a picnic table but hey its you doing the work :-)
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 05-23-2006, 11:36 AM   #6
Paperhanger/painter
ProWallGuy's Avatar
True, good call. But after 7 months or so, he probably assumed he got all he was going to get. Until you showed up. :D
ProWallGuy
ProWallGuy is offline   Reply With Quote
Old 05-23-2006, 10:43 PM   #7
Contractor
You also need a UV resistant varnish and I'm not a poly fan especially on exterior finishes. Boat finishes are more adapted to exterior use and the 'spar' varnish at the box store is not marine varnish.
Teetorbilt is offline   Reply With Quote
Sand in the rocks of my desert landscaping... Not Sure Landscaping & Lawn Care 3 06-27-2007 11:14 AM
painting sand over sand heather Painting 1 04-03-2007 11:35 AM
Sewer leak below slab. Debris in sand. martin52 Plumbing 2 10-20-2006 09:43 AM
Can you sand concrete? AllGoNoShow Carpentry 1 10-17-2006 02:36 PM
Sandblasting...sand, sand everywhere! Glittergoddesss Painting 1 07-28-2005 11:47 PM
