Rusting Nails On Doorway - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 08:59 AM   #1
It's always something
Rewards Points: 150
Rusting nails on doorway
On the casing around my entrance door from the outside, some nails have rusted and started to bleed. I bought some Rustoleum paint designed for meatal doors and plan to repaint the casing, trim, and door. Its cranberry so it should look great after I'm done!
As far as the rust stains go, will Rustoleum take care of the nails that are bleeding or should I do additional prep?
SingleGuy is offline   Reply With Quote
Old 02-26-2012, 09:25 AM   #2
Yes and no, respectively.
The Following User Says Thank You to jsheridan For This Useful Post:
SingleGuy (02-26-2012)
Old 02-26-2012, 09:45 AM   #3
Rewards Points: 150
Awesome. Thanks so much!
The Following User Says Thank You to SingleGuy For This Useful Post:
jsheridan (02-26-2012)
Old 02-26-2012, 11:32 AM   #4
Too Short? Cut it Again!
Wire or fiberglass brush the rust. Then use a rust convertor spray primer if some remains or a rust inhibitor primer if you got it all.
The Following User Says Thank You to user1007 For This Useful Post:
SingleGuy (03-15-2012)
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
nail guns & nails koodawg Tools 4 12-06-2010 10:05 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Rusting nails on exterior firsthomegal Painting 7 05-28-2007 05:15 PM
