Running Out Of Time To Paint - Painting - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 01:13 PM   #1
Running out of time to paint
i was told that the outside temperature has to be over 40F to paint. So, i figure i have about four weeks left until it is too cold. Maybe less, it usually gets cold around mid-October. So what all needs to be done before i can paint my countertops? I know the subfloor needs finished, but do the cabinets have to be painted first? Do i need to sand the countertop first? What about the hardwood, does it have to be installed before i can paint?
firsttimeremode is offline   Reply With Quote
Old 09-25-2012, 05:09 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 618
You painting all that stuff outside?
Old 09-25-2012, 06:18 PM   #3
Too Short? Cut it Again!
I am confused too. If it is an indoor kitchen, even in a semi-abandoned yet to be lived in place, won't you have to turn the power on for some heat anyhow? If you can close of the room, it seems to me a SAFE type of space heater is in your future? Drop some plastic in the doorways.
I don't like remembering but I have worked in interiors of homes under renovation with no occupants where the temperature outside was 20 below. Minimal heat was provided not for me, because I was not worthy, but to keep pipes from freezing. It is pretty hard to get the interior of a house, even with crappy insulation, down under 40F with any heat going at all.
You are correct though. Paints and varnishes do not like drying or curing below a certain temp. And whether 40 is the mark is somewhat irrelevant. I would not lay down a nice varnish or poly on a surface at 42 and not expect dust to stick to it while it took forever to dry. Good news is humidity should not be a factor. Cold air just cannot hold much moisture. Getting things to dry when it is 100 degrees and 400 percent humidity does not work either.
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (09-25-2012)
Old 09-26-2012, 01:10 AM   #4
it will be painted inside, actually, and no heat at all. We have to rely on coats for now, once the house is done and move-in-ready we can have the electric hooked up. (local electric company rules). the subfloor was finished today, so now i just have this bit of painting, repairing the floor of the cabinets, and the hardwood.
Old 09-26-2012, 03:40 AM   #5
chrisn's Avatar
Rewards Points: 618
You will need to get it to at least 50 for proper painting, I would think.
Old 09-26-2012, 03:55 AM   #6
Can't you bring in fuel burning heater and a watchful eye on it while you work?
Old 09-26-2012, 08:12 AM   #7
Could. Dont have one, all i have is two space heaters that plug in, and they arent doing much good. Oh well maybe i can get the cabinets repaired tonight, and then i can paint tomorrow or the next day. Hopefully. Im hoping the cabinets dont prove difficult to repair.
Old 09-26-2012, 08:16 AM   #8
BTW this is in East Texas so there is no moisture. At All. Most of the year its 100 degrees outside and no moisture, no breeze, no humidity, no nothing. Just heat. Unless it happens to rain, which it doesnt do very often.
Old 09-26-2012, 09:51 AM   #9
Rewards Points: 6,034
I think your question about temp. has been answered and yes i would paint the cabinets before I installed the floor. I am not sure what kind of counter top you are sanding and painting but do every thing you can before hardwood floors. why take a chance on spills, splatter, or dropping something that would damage the floor.
Old 09-26-2012, 11:11 AM   #10
yeah. they are laminate countertops, which suck in every way except shape, which i love and i havent seen on any of the stone countertops. So, i got some Giani granite countertop refinishing paint, and that will make it resemble granite instead, and im painting the cabinets chocolate with silver handles. the dark wood floor will tie it all together.
Old 09-27-2012, 08:24 AM   #11
I have never used that product please let us know how it worked for you, Good Luck.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Sherwin-Williams Paint: Drying Time For Taping Twister Painting 10 07-16-2011 09:55 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
