Rounded Wall Corners - Painting - DIY Chatroom Home Improvement Forum
Old 02-07-2007, 07:41 PM   #1
Post
Rounded wall corners
Does anyone know how to go about switching paint colors on a rounded wall corner? I am in need of help figuring this one out... HELP!!
Jiffner is offline   Reply With Quote
Old 02-07-2007, 07:51 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Outside corner, or inside corner?
slickshift is offline   Reply With Quote
Old 02-07-2007, 07:52 PM   #3
Outside corner
Old 02-07-2007, 08:10 PM   #4
Actually both inside and outside now that I think about it. UUGGGHHH!!
Old 02-07-2007, 08:15 PM   #5
slickshift's Avatar
You'll want to decide which room "gets" each corner visually
Whether the corner should be mostly A or mostly B
Does it "belong" to the living room, or the dining room
You'll want to look at the area from any other areas where you can see it (staircase, kitchen) to help you decide
Once you figure it really should be family room (or 50/50 or whatever), then decide about where the "line" should be
I like to make these lines by rolling one color right up to where I want it, but that doesn't always work for every situation
It often won't work for inside ones (though the mini-rollers might work)
You may need to tape the line with painter's tape to help you get a straight, crisp, line
Old 02-08-2007, 12:32 AM   #6
Pro Painter
I also use slick's method. Just roll top to bottom towards the corner until it looks right. Get it as straight as possible, then leave it until you do the other color, roll that as close as possible and cut it with a brush. You can go back and forth with both colors until you're satisfied.
Or, use tape.
You can use a plumb bob to mark lines and then snap a chaulk line. Problem with this is that the corners may not be straight up and down. So tape or freehand is preferred.
joewho is offline   Reply With Quote
Old 06-08-2007, 08:58 PM   #7
Workaholic's Avatar
Rewards Points: 268
Or, use tape.
I concur
Workaholic is offline   Reply With Quote
Baseboards around Rounded Corners hgiljr Carpentry 13 09-10-2012 06:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
