Old 02-16-2013, 05:28 PM   #1
Rough estimate?
Guys-
May be moving into a new house and would look to remove popcorn ceiling from two ceilings (one is a tray ceiling) roughly 18x18. Also, remove wallpaper from 2 walls (12 wide by 8 high) and wallpaper from underneath a chair rail around a dining room. This and paint 3 rooms, each roughly 15x15. I know this is vague, but any rough estimates for having it professionally done?
asbury park is offline   Reply With Quote
Old 02-16-2013, 05:39 PM   #2
747
registered
747's Avatar
Rough estimate?
Guys don't like to throw out numbers here. I don't have a clue. This is labor intensive. Popcorn ceilings are a mess to take down. The wallpaper will either go smooth or not. Then its special primer(something like Zinsser GARDZ) and a good quality paint.
747 is offline   Reply With Quote
Old 02-16-2013, 05:40 PM   #3
paper hanger and painter
chrisn's Avatar
Rough estimate?
no way to tell from here
The Following User Says Thank You to chrisn For This Useful Post:
oh'mike (02-16-2013)
Old 02-16-2013, 07:12 PM   #4
Super Moderator
Rough estimate?
You will ,very likely, be getting time and materials prices on those jobs----I'm on a wall paper stripping job and the paper was installed over unpainted drywall---total skim coat is needed---$$$$---We would already be done painting if the paper came off without the wall damage----
Old 02-17-2013, 06:35 AM   #5
chrisn's Avatar
Rough estimate?
freeking "paper hanger" should be hung by his or her thumbs till he or she repents
Old 02-17-2013, 06:41 AM   #6
Super Moderator
Rough estimate?
Work is work----a paycheck is a paycheck---
Old 02-17-2013, 08:26 AM   #7
Gymschu's Avatar
Rough estimate?
$85,000 should cover it.
Old 02-17-2013, 09:23 AM   #8
Super Moderator
Rough estimate?
I'm putting you in charge of billing and collections----and offering you 50%==sound good?
Gymschu (02-17-2013)
Old 02-17-2013, 05:54 PM   #9
chrisn's Avatar
Rough estimate?
I would do it fo $80,000
Old 02-17-2013, 05:57 PM   #10
chrisn's Avatar
Rough estimate?
Believe me ,I know. It just blows my mind that a "pro" paper hanger will not take the responsibility to do it right. It takes MAYBE an extra hour to prime the walls
Rough estimate to build a simple bathhouse by the pool? Anoura22 Building & Construction 4 04-11-2012 07:32 PM
rough estimate of cost for my project rmccoy Building & Construction 4 11-15-2011 12:08 AM
How to rough estimate cost of replacing windows/doors OlyTDI Building & Construction 7 11-01-2011 12:51 AM
rough estimate of foundation on slope billv Building & Construction 4 07-20-2010 10:12 AM
Rough cost estimate requested reznor74 Electrical 1 10-28-2009 07:37 PM
