Rough Cedar Trim - Painting - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 08:32 PM   #1
rough cedar trim
I'm wanting to keep the rough cedar trim I'm going to install natural except I want to waterproof it permanently. I was told to use some deck stuff. I don't want to have to redo this every year ! I asked about using polyurethane but was told the wood aroud windows needs to breathe. Is this true ? What can I do ?
sandersmd is offline   Reply With Quote
Old 05-23-2011, 08:49 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
cedar does not need to be treated. you can leave it natural if you wish.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
sandersmd (05-31-2011)
Old 05-23-2011, 08:52 PM   #3
Too Short? Cut it Again!
You could use a transparent/clear sealing product for cedar, redwood, etc. but as has been discussed recently in these forums you would be better off with a semi-transparent stain to blend the color and provide better UV protection. The quality of material you get, sun exposure and weather conditions, etc. will be the determining factors in how often you are going to need to apply.
The natural oils in the cedar will make it difficult to get much life out of polyurethane over the top. You should also avoid products with wax in them such as Thompson's.
The Following User Says Thank You to user1007 For This Useful Post:
Old 05-25-2011, 01:17 AM   #4
Rewards Points: 150
well, is it interior or exterior? exterior, i would use a clear, transparent oil stain to seal it and waterproof it. you'll have to redo it every couple of years (in worst case scenerios) I would recommend Sansin classic stain. their natural is just a clear. Good product.
hammerheart14 is offline   Reply With Quote
The Following User Says Thank You to hammerheart14 For This Useful Post:
Old 05-31-2011, 06:03 PM   #5
another cedar question
Before I knew not to use a product like Thompson's I already did on some cedar posts on my porch. Should I use a deck wash product on them and maybe sand them then go back with the uv stain ?
New basebords and trim are white but all window frames are stained cedar? mibson Interior Decorating 0 01-22-2011 01:27 PM
repairing damaged cedar trim Master Brian Remodeling 3 09-10-2010 12:30 AM
Rough sawn cedar doesn't look the same bluefitness Carpentry 2 06-05-2009 07:52 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
