Rotted Wood Window In Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 11:43 AM   #1
rotted wood window in bathroom
I live in a building in New York city run by a slumlord. The bathroom defies belief (you want to talk mildew?), and my wife's mental state has suffered greatly. She cries. You can imagine.
I'll focus on the bathroom window, so as not to overwhelm you (or me).
The window frame and sill in the bathroom is wood. (See picture.) It is right next to the shower, which has soaked the window for several generations of tenants. There were about fifty years worth of nails, screws, brackets, etc. in the window, covered with about a half-inch of paint. Pulled them all up (yay me! Trying not to think about how much lead paint I've ingested). Huge holes resulted. No problem. I will use oil-based spackle, fill the holes, and cover the whole thing in oil-based paint. That should take care of shower spray, I'm thinking.
Here's the The sill of the window has (or should have) long ceramic tiles covering it. The tiles were loose, so I pulled them up. Soaking wood underneath. Totally, completely, soaking, as in: you touch it with your finger, and water comes up. First half inch of wood came right up with scraper, totally rotted by the water.
This is my plan. Tell me what you think:
I've got the fan trained on the sill, and hoping it dries in a few days (no showers for my wife?). After that, I'll soak it with oil-based paint. Then put the tiles back on (not too sure how to do this--but I know I need a solid dry base).
What should I keep in mind here? Are there any products I can use without a respirator? I don't want to die from cancer, even to keep my wife from crying.
Thanks!
sgsnow is offline   Reply With Quote
Old 06-16-2010, 06:58 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
you would be much better off replacing the sill, you will never get it dry enough for paint to stick, let alone tile.
Old 06-18-2010, 02:27 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
I agree. I would probably use pressure treated. As you have seen, water will get behind tile.
Tags
painting , primer , wood rot
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Typical to put foam between wood bucking and window opening ? heydade General DIY Discussions 2 10-10-2009 12:59 PM
Bathroom wood flooring options? JamesEric Flooring 6 03-28-2009 10:03 AM
Sorta waterproof window for OVER a tub shower bathroom justdon Remodeling 5 09-16-2007 09:27 PM
