Rolling Pattern: Up/down Vs The "W" - Painting - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 11:17 AM   #1
rolling pattern: up/down vs the "W"
I am a little confused which is the better approach. When you read DIY books or stuff at stores they always talk about rolling paint on in a W patterns to produce a random patterns. When ever I watch a pro at work they just go up and down. I work in the corporate world at a huge facilty so there are always walls being painted. Plus, if you watch the HGTV stuff the pros on there never paint in a W patterns. What gives? Someone explain this.
beerdog is offline   Reply With Quote
Old 03-31-2011, 11:26 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The "W" pattern is used to spread the paint out into a 2-3' area as you first set the roller onto the wall.
Then you roll straight up and down.
If you rolled straight up and down upon first contact, there would be too much wet paint concentrated in a 9" area.
The "W" should be applied in the unpainted (dry)area and you work back into the the wet area.
If you start in the wet area and work out, you don't have any paint left as you get into the dry area.
Make sense?
I'm painting 5 rooms as we speak so I'm getting pretty good at the "W".
Hope this helps
tcleve4911 is offline   Reply With Quote
Old 03-31-2011, 01:52 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
The "w" is for when you are first starting out as a painter. Start with a full roller about 2/3 of the way up the wall and about one roller width from where you left off depending on how the paint is spreading. Roll from the 2/3 starting point all the way down and then all the way back up then move towards where you left going at an ever so slight angle towards where you left off till it is even, then change direction and move through where you started this run continuing till you are ready to load up again.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 03-31-2011, 02:31 PM   #4
maybe it is the pictures. They always show people making these little W's. I have painted a bit arround the house and I think I natuarally do what you are describing.
Old 03-31-2011, 06:07 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
I think the biggest problem is they always show someone with the roller frame in their hand, and not on an extension pole.
No pro ( or informed DIY) holds the frame for anything other than a small area. Put it on a pole that you can comfortably roll top to bottom in a single motion.
Then when applying paint, depending on the cover and the spread rate of the paint, do a "slight" V or w covering about 1.5 x the width of the roller, spreading evenly from top to bottom. Finish with a stroke in the same direction, top to bottom. repeat.
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
Ole34 (03-31-2011), tcleve4911 (03-31-2011)
Old 04-02-2011, 09:14 AM   #6
Just painted my bathroom and conciously payed attention to this. Definetly makes a difference. Next questions.....
Which end of the roller should face the wet paint being worked into, frame end or open end? Should I put more pressure on on either end?
Old 04-02-2011, 12:15 PM   #7
Variation of "W" Technique
Hi All,
I just read a slight variation of the usual "W" technique in Home Depot's "Decorative Painting 1-2-3" book.
They say to paint a W on an 18" by 18" area, which is about 2-3 square feet and then roll it out by going up and down. This is then repeated on a 2-3 square foot adjacent area. They then say to lightly load the roller and backroll the 4-6 square foot area in the direction of the floor to the ceiling.
This does make sense to me but they did say something else in the book that I found somewhat troubling. They said that the minimum size ladder for standard eight foot ceilings is four feet. To me, that is just too short a ladder to do the job safely!
Bob
Bob Guercio is offline   Reply With Quote
Old 04-02-2011, 12:32 PM   #8
Originally Posted by Bob Guercio View Post
Hi All,
Bob
Hey Bob, good to see ya. I chuckled when I read about the ladder, a lot of times I use a two foot ladder. But, I'm a pro, don't you try that at home. It's less height to fall from.
Old 04-02-2011, 12:37 PM   #9
Gymschu's Avatar
Rewards Points: 658
Forget that "W" stuff, that's a bunch of DIY baloney. Up and down is where it's at. I see people doing the "W" and go too slow and then when the paint dries, you see the "W" under the paint film. What a bunch of hokey. Where the wall meets the ceiling I go horizontal with the roller to blend it in with the "cut-in." Then you go up and down the length of the wall moving along at about 9-18 inches at a time. No messin around as you want to keep a wet edge. You can rest when you get to the corner.
Old 04-02-2011, 12:58 PM   #10
Thanks Joe.
I've always used a five foot ladder for eight foot ceilings and I recently purchased a six foot ladder for the same ceilings. It was also a bit sturdier.
In any case, sturdiness aside, the extra foot gives me a more secure feeling because the top rung is always within reach to hold on to.
Bob
Old 04-02-2011, 05:14 PM   #11
Forget the W or N or whatever the DIY books and shows say as gospel. Top to bottom, corner to corner. I'm guessing that some of you out there have even used a "5 gallon" ladder in a pinch.
kboyz is offline   Reply With Quote
Old 04-02-2011, 11:40 PM   #12
Faron79's Avatar
Rewards Points: 260
I always coach our customers/"infrequent Painters" on a "Hybrid" technique...
I have them work ~a 3'-wide column on a wall...
* Roll horizontally over the cut-in, but slightly lift roller at the edge, so only a light roller-stipple overlaps cut-in.
* 4 rollerloads per column, starting @ top-left.
* Each load about 2'x3', applied using your favorite letter!
* 4th load in lower-left.
* Right after this, bring roller immediately to upper-left of this column, and do the long/light/continuous "sweep" from ceiling-to-floor.
* I tell-'em to think of a plane taking-off....
* Repeat this column/sweeping technique around the room.
>>> I've actually had customers come back in and thank me for describing this method to them!
I don't tell them about doing the whole wall with only the long strokes. It takes a REAL pro to do that!!
Most average Joes' will push paint waaaayyy too thin doin' that.
Faron
Faron79 is offline   Reply With Quote
Starting a "hopscotch" pattern... shaggyb Tiling, ceramics, marble 6 01-03-2012 10:48 AM
Ceiling pattern -- HELP! DM28675 Painting 4 09-08-2010 05:01 PM
whole/half pattern composite shingles new homeowner Roofing/Siding 2 09-09-2009 09:15 PM
pattern in floor ponch37300 Tiling, ceramics, marble 7 06-08-2009 08:40 PM
Shingle Pattern gilberte Roofing/Siding 7 09-05-2005 03:37 PM
