Old 02-22-2011, 06:00 PM   #1
Question
Rolling paint
Can I get a sprayed on look rolling latex paint with floetrol, and a smooth finish roller skin?
Sam Flores is offline   Reply With Quote
Old 02-22-2011, 06:52 PM   #2
Coatings Nerd
Rolling paint
Are you asking about walls? Or doors and trim?
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-23-2011, 11:16 AM   #3
Cool
Rolling paint
Good morning NC, It would be doors and trim(interior). They were originally going to have a heavy grain look, so I was just going to brush. Then the style was changed to a smooth surface. I'm trying to stay away from having to spray them. As things go, the budget remained the same and I'd rather not spend more on materials(spraying would reqiure more paint). Thank you for your time. Sam
Old 02-23-2011, 11:28 AM   #4
Coatings Nerd
Rolling paint
Use oil, and forget the floetrol. Oil is much more forgiving, and will give you a nice smooth finish. Dry times will be longer.
Floetrol is ok, but its hard to get the same look, its also easy to add too much which will result in the paint not drying properly, remaining sticky, or drying soft. Sometimes a combination of all.
If you dont want to use oil, Benjamin Moore has an oil product that is soap and water cleanup called "Advance". SW has one too, in their Pro Classic line. I have no experience with the SW.
Old 02-23-2011, 12:14 PM   #5
Gymschu's Avatar
Rolling paint
I have had success in the past with mohair roller covers and alkyd paint to get the look you are seeking. The mohair will still produce a bit of texture but not as bad as a regular cover........and, it won't leave pieces of cover in your nice paint job. If you practice a bit on some scrap wood or metal, you can achieve a nice "almost sprayed on" look.
Gymschu is online now   Reply With Quote
Old 02-23-2011, 12:17 PM   #6
Rolling paint
Thanks for your help NC.
Old 02-23-2011, 06:15 PM   #7
Super Master Painter
Ole34's Avatar
Rolling paint
i use oil, paint thinner and a 2.5'' flat when i want a glass finish......
Ole34 is offline   Reply With Quote
Old 02-23-2011, 11:00 PM   #8
Painting Company, NY
housepaintingny's Avatar
Rolling paint
I'm familiar with Sherwin Williams Pro Classic and it is a great paint for trim, doors, and cabinets. if you use a 1/4 inch nap mohair roller cover you should have no problem getting a smooth finish. I've painted tons of commercial metal doors and frames over the years and have always used a low nap mohair roller cover and the majority of the time you can't tell that the doors where not sprayed.
housepaintingny is offline   Reply With Quote
Old 02-26-2011, 01:04 PM   #9
Rolling paint
Thanks to all for your time and input. Just got the message that the paint to be used is a low sheen. Do you agree that with a floe agent and the proper skin I will get good resultsSam
Old 02-26-2011, 01:08 PM   #10
Rolling paint
With quality paint, a low nap mohair roller, and proper preparation you will get great results. I personally never thin any paint, I have really never had a reason too. I have painted countless doors including metal doors and frames and have had them come out looking great using a mohair roller and quality brush.
Old 02-26-2011, 06:32 PM   #11
Rolling paint
The paint to be used is a Dunn Edwards low sheen, so I do trust its quality. Thank you so much for your time Sam
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 10 12-17-2009 04:34 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
