Roller Splatter - Painting - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 04:38 PM   #1
Roller Splatter
I am getting ready to paint one wall an accent color but do not want splatter on the 2 adjacent walls when I roll. Do the pros usually cover the adjacent walls with plastic when painting just 1 wall a different color?
dyier is offline   Reply With Quote
Old 01-14-2008, 06:26 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Would be a good idea. I myself have never had to cover furniture, or walls, guess its in the technique. But yes, you are much safer to do that and use painters tape so as not to pull off the paint
USP45 is offline   Reply With Quote
Old 01-14-2008, 08:14 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
No, never
After "cutting in" the first two to four inches with a brush, a premium quality paint with a premium quality roller sleeve, a little concentration on technique (not zinging that thing up and down like a zipper) and there's no need to worry about splatter
slickshift is offline   Reply With Quote
Old 01-16-2008, 01:40 PM   #4
Workaholic's Avatar
I agree with Slick just pay attention to what it is that you are doing, and you should be alright.
I would make sure that your first roll is just slightly over a bit, and then you can back roll just a bit after getting it good and wet. A fresh roller will splatter more than one that has not had the paint worked into it.
Sean
Workaholic is offline   Reply With Quote
Old 01-16-2008, 02:54 PM   #5
Rewards Points: 506
I have never had spatter issues... I suspect that the best way to avoid it would be to:
1) Use high-quality paint from a paint store.
2) Use a high-quality cover of sufficient nap.
3) Make sure the cover stays "wet" with paint.
4) Don't roll too fast.
5) Roll up/down, not left/right.
SirWired
sirwired is offline   Reply With Quote
How do you use a loop roller? redline Painting 8 04-02-2013 10:05 AM
Do they make a extra long roller? Shpigford Painting 4 07-15-2011 09:15 PM
Power Paint Roller Recommendation - Home Use handy man88 Painting 4 10-29-2007 06:40 PM
Roller Marks jfarringdon Painting 4 09-28-2007 07:48 AM
Roller Marks - Please Help andru04499 Painting 3 09-16-2007 09:53 PM
