Old 06-02-2009, 07:16 PM   #1
Haste Makes Waste
Which roller sleeve to use
I just bought 1/2" nap roller sleeves to use on smooth plastered walls. I just noticed on the pkg it says for flat paint and semi-smooth surfaces. Will these be okay to use or should I exchange them? I'll be using satin paint on smooth plastered walls.
saggdevil is offline   Reply With Quote
Old 06-02-2009, 10:00 PM   #2
100 Year Family Tradition
4ThGeneration's Avatar
I always use the 3/4 inch for the flat paints with the larger naps for stucco and such. I would use 1/4 with semigloss, so the 1/2 should be fine.
Now you said plastered, but I find that this is a generic keyword with most people. Is it plaster or drywall?
4ThGeneration is offline   Reply With Quote
Old 06-02-2009, 10:07 PM   #3
Haste Makes Waste
It is plastered walls. (1913 house) I am in process of stripping 96 years of painted wallpaper, lol, about 3/4 done. But I had just finished the DR and had problems getting the paint on walls with 3/8 sleeve. Was using Purdy WHite Dove 3/8". Was advised to go to 1/2" to hold more paint as the walls are 10-12ft high. Guess I just didn't realize they make the sleeves for smooth and semi-smooth. That being said, is it okay to use the semi-smooth for flat paint sleeve on a plastered wall with satin paint?
Old 06-03-2009, 05:12 AM   #4
paper hanger and painter
chrisn's Avatar
They just say that to cta, you will be fine. You have to learn to trust me.I have been restoring old plaster walls for 25 years
How do you use a loop roller? redline Painting 8 04-02-2013 10:05 AM
When to change paint roller sleeve saggdevil Painting 4 05-28-2009 09:56 PM
Re-using compression nut and sleeve on another brand of shut off valve? DIYGST Plumbing 4 01-19-2009 01:44 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Roller Marks - Please Help andru04499 Painting 3 09-16-2007 09:53 PM
