Roller Skim Coating - How To - Painting - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 06:00 PM   #1
Roller skim coating - how to
I have seen some videos of people skim coating drywall by using a roller and very thin compound. Anyone know how to do this? Any advice on technique and equipment?
beerdog is offline   Reply With Quote
Old 12-29-2008, 07:40 PM   #2
Workaholic's Avatar
Rewards Points: 268
I stick with the broad knifes.
Sean
Workaholic is offline   Reply With Quote
Old 12-29-2008, 07:41 PM   #3
General Contractor
We do this all the time.
Get a box of all purpose mud. Place about half of it into an empty 5 gal bucket. Using a mud mixer on a drill blend in enough water to get a loose milkshake consistency.
Use a 1 1/2 inch roller cover, dip into the mud and apply to wall. Apply to a small areas then pass a 14" taping knife to smooth it out.
Do a small area first to test the consistency, you may need a little more water or add a little more mud till it feels right. With experience you will be able to mix it by feel, but at first there will be a little trial and error to get it right.
For small areas your probably better off hand tapping. For large areas I set up one guy with a roller and one following behind with a knife. You can really knock out large areas pretty quick.
jensenconstruction is offline   Reply With Quote
Old 12-29-2008, 07:58 PM   #4
Hi everyone, it's mostly trail and error, i have finished drywall for many years and have tried alot of
different methods.I candle my walls and ceilings with light held at a angle to spot imperfections and primer
before paint.Sheetrock brand First Coat is great for smooth finish.
Frederick j Ward is offline   Reply With Quote
Old 12-29-2008, 09:08 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Do exactly what jensenconstruction said. Also, use a 5 gallon paint grid in that bucket o' mud.
Sir MixAlot is offline   Reply With Quote
Old 01-10-2009, 11:00 AM   #6
Well, I finally tried this out on a small wall that needed to be skimmed. I just used a small amount and a 3inch roller. I was suprised how easy this was. I had to waste some mud and a cheap roller, but it was soooo much easier. It seemed like the results were better also with less touch up and less sanding. This will definaty be my approach for finish skim coats int he future. Thanks for the advice.
How do you use a loop roller? redline Painting 8 04-02-2013 09:05 AM
Skim coat peeling in bathroom. ? 2031pratt Painting 17 03-05-2009 02:33 PM
Skim coating wall help pesphoto Building & Construction 3 05-03-2007 06:43 PM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 05:08 AM
