Old 12-02-2011, 05:39 PM   #1
retired guy
roller naps
I've been using 3/8 nap woven covers for almost all of the interior repaints that I do. I usually follow with a 1/4 nap for the second/finish coat. From where I'm standing (unprofessional eye), the result looks fine. I tend to use pro mar 200 eg shell sheen. I've read here that using a 1/2 nap for flat paints is preferred. I've found them to be harder to work with when they're fully loaded. Also, doesn't it tend to put the paint on thicker than it should be? What would you recommend for satin finishes? Matte finishes?
igneous is offline   Reply With Quote
Old 12-02-2011, 06:25 PM   #2
ltd
roller naps
generally speaking for flat or satin on texture walls, 1/2 purdy white dove, for dry wall or smooth plaster, 3/8 white dove.for ceilings smooth or texture using a flat ,1/2 white dove. for a smooth ceiling useing satin 3/8. i never use a 1/4 for anything thing ,maybe rolling a flat door p/s you say you use 200 egg did you ever try 200 low sheen imo its just right.
ltd is offline   Reply With Quote
Old 12-02-2011, 06:32 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
roller naps
My cover of choice is a Wooster 1/2 Super Fab.
Its all about technique to spread it out about 1 1/2 roller width , couple of strokes to even out, finish with top to bottom straight stroke.
I can use this cover for just about any finish- I don't roll or leave rolled) enamel trim finishes.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (12-03-2011)
Old 12-02-2011, 10:21 PM   #4
roller naps
Igneous, I use 1/2 for flat and matte always, and eggshell most times. In a large room I'll use 1/2 for eggshell, but small rooms like kitchens, baths, or anywhere where your eye is close to the wall, I'll use 3/8. Always use 3/8 for satin and above for walls. I would never roll anything on a ceiling with less that 1/2 inch. However, I rarely roll anything but dead flats on ceilings. I have used 1/4 and mohairs to roll sheens on some highly decorative jobs, again, small rooms, but the walls have to be pristine. 1/4 and mohair are good for rolling sheen enamels on trim, like flush doors, cabinet bodys, wood paneled walls, etc. The real short naps leave a nice, uniform factory looking finish.
Old 12-03-2011, 09:33 AM   #5
retired guy
roller naps
I really appreciate the feedback. I read somewhere where painters on "high end" jobs always finish with 1/4 nap for a smoother, less textured look/feel. Thus, I tried to follow in that method. Apparently, none of you guys agree. Any truth to that theory? You were quite specific on various uses, but I must ask, why is the 1/2 nap cover so widely preferred? Any reasons for NOT using the 1/4 nap? Didn't know 200 had a low sheen finish. I will give it a try. As always, thank you for your advice.
Old 12-03-2011, 10:13 AM   #6
roller naps
The 1/2 will carry some material and move at twice the speed. Plus it is much easier to spread evenly when you have something to spread.
It is clear you live in the land of smooth walls- this makes a difference too- so do I.
Old 12-03-2011, 12:30 PM   #7
roller naps
From the land of smooth walls. Used to be that you could roll flat with a 3/8. No more, ever. It just won't hold enough to do an effective job, as bj says. If I can roll a wall with five dips versus your ten, I'm getting it done twice as fast, putting more paint/better coverage, and you're twice as likely to have unsightly markings on your wall and skippers (holidays). Igneous, as to finishing off walls with successively finer naps, I don't think that does anything, as a heavier nap texture isn't going to be hidden by a lighter nap, but will make a hodgepodge texture. Have you ever seen a door that has been both rolled and brushed over it's lifetime? I would rate this in the hairbrain category of things I've seen online. sorry.
Joe
Old 12-03-2011, 01:21 PM   #8
Gymschu's Avatar
roller naps
Like everyone has said, your roller just doesn't hold enough paint if it's 3/8 or less. I almost always use 1/2 inch & no one has complained that I know about.
Old 12-03-2011, 01:35 PM   #9
retired guy
roller naps
OK. I'm sold on the 1/2 nap. Nice to know where to go for answers to popular painting problems. The "hodgepodge" image makes perfect sense. Thanks. Merry Christmas to all.
Old 12-03-2011, 03:14 PM   #10
sdsester's Avatar
roller naps
Look. The whole idea is to apply paint so in many years, I have never used anything less than 3/8 and usually go with 1/2 even for flat finishes. Chrisn climbed on me once for suggesting I can get a nice finish with semi-gloss using 3/4 on kitchen cabinet doors and so forth. Geezers who trained me would have slapped me if I showed up with 1/4 inch cover. As I remember, he says he can get a nice finish with 1/4 foam things. Same objective and same result I suspect. My cured film layer is probably going to hold up better? I don't know. He will pipe in here but would never suggest anything less than 3/8 for priming and finishing a wall?
I remember well a client complaining it took her husband ages to paint a masonry surface. I used a 1" or 1.5" nap roller and flew through the project like any other. Chased drips around mortar joints with a brush.
I did differ from other painters in that I seldom tried to make roller covers work from job to job. I bought nice ones, wrapped them in plastic and even stuck them in the frig until done. I just didn't see the logic in running fresh water, typically at 12gpm for 20-30 minutes to save, at my cost, $5 worth of roller cover.
sdsester is offline   Reply With Quote
Old 12-03-2011, 03:32 PM   #11
roller naps
20-30min to clean a roller cover?
3-4 tops
But that is a different discussion...
And we've had it, many times!
Old 12-03-2011, 04:46 PM   #12
sdsester's Avatar
roller naps
3-4 tops
True but point is the same. And I hope the discussion comes up again. 12 gallons per minute of fresh water my friend. 36-48 gallons of fresh water if you are as fast at rinsing $3-5 covers as you claim. I live in a State that is running out of fresh water. The utility that provides, or at least bills for it, is in Germany.
Old 12-03-2011, 04:55 PM   #13
roller naps
Good point about the drought states. There are ways of reusing water- using less etc. Some even with plenty of water throw- some wash.
I'm a washer because I think Super fabs work better after a couple of washings.
But those that do it often find a system that works for them.
I'm not saying one is better.
Old 12-03-2011, 04:56 PM   #14
roller naps
..and your water pressure must be awesome at 12gpm..
Old 12-03-2011, 05:55 PM   #15
paper hanger and painter
chrisn's Avatar
roller naps
Yes I did
No, I did not
No, I will not,I NEVER use anything less than a 1/2, but prefer Wooster 50,50 3/4 for all walls
I would also argue about the last papagraph but as Brush said it has been gone over and to each his(or her) own
Wet Edge on Walls: How Far Per Roller Load? Twister Painting 10 11-23-2011 05:28 AM
Exterior Painting-Brush or Roller? Smokin Gun Painting 8 07-12-2011 05:02 AM
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 12 01-14-2011 09:50 AM
Flashing --> how does it occur and how to prevent it gramps416 Painting 5 05-27-2010 12:11 AM
Roller advice/Surface Issues? gmhut Painting 6 03-10-2010 09:32 AM
