Roller Marks - Please Help - Painting - DIY Chatroom Home Improvement Forum
Old 09-15-2007, 08:49 PM   #1
Hello - I'm in the process of painting the interior of a new construction property with an eggshell flat paint. The walls have already been painted by the developer with a flat white. I just finished my first wall and I have a lot of roller marks showing. Can someone please tell me the appropriate size nap I should be using and please explain why the roller marks are appearing. I read somewhere that I should try adding some water to my paint, will this solve my problem?
Thank you in advance for your help!
andru04499 is offline   Reply With Quote
Old 09-15-2007, 09:48 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The biggest causes of roller marks are
1) poor quality paint
2) poor quality roller sleeves
3) poor technique
So
1) Use a premium paint from Ben Moore, Sherwin Williams, Pittsburgh, or California (they all make cheapo stuff too, get the good stuff)
2) Use at minimum Purdy White Dove sleeves, and I'd recommend a quality 50/50 woll/poly or 100% wool from Wooster or Purdy
3) Apply the paint, lay it on...don't squeeze it out
The biggest technique mistake is people thinking they have to squeeze every last drop out of the sleeve...not so
Apply-Don't Squeeze
3a) Maintain a wet edge...don't let the edges of what you've rolled dry out before hitting them with the roller when doing the next section over
As for nap, it's not really a factor in roller marks
I'd recommend 1/2"...or if that's too much then a min. of 3/8"
But really try 1/2" if you can, it'll go much faster and you'll have more "wet" time before seeing those marks
Oh no...not at all...that's horrible...wherever you read that, stop reading from there
That's really a bad "tip"
slickshift is offline   Reply With Quote
Old 09-16-2007, 07:50 PM   #3
Thank you for the info. I painted today and I did not squeeze all the paint from the the roller and it worked, no roller marks! Thanks again for your help....
Old 09-16-2007, 08:53 PM   #4
slickshift's Avatar
Sweet, glad it worked, thanks for the update!
How do you use a loop roller? redline Painting 8 04-02-2013 09:05 AM
Trail marks on hardwood floor - HELP!! Hitchcock Flooring 1 08-06-2007 09:23 PM
Use Paint Roller to put on 3rd coat of mud question... KUIPORNG Remodeling 3 02-10-2007 06:50 PM
to spray/power roll? putri Painting 10 07-20-2006 02:34 PM
Loop Roller redline General DIY Discussions 2 03-21-2006 07:27 PM
