Roller Marks From Painting - Painting - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 07:32 AM   #1
roller marks from painting
How do I get rid of the roler mark after the paint has dried?
bootz1 is offline   Reply With Quote
Old 09-13-2012, 08:33 AM   #2
Rewards Points: 13,472
Sand them. I use a sanding pole, sanding pad, and medium grit screen cloth.
It's all sold in the drywall area at the box stores.
Screen cloth will not load up as bad as sand paper.
Old 09-13-2012, 11:25 AM   #3
Gymschu's Avatar
Rewards Points: 680
You shouldn't have roller marks if you use your roller properly. Load a 1/2 inch nap roller with plenty of paint, roll in an up and down motion, not a "W" like the HGTV shows tell you to do. Let the roller do the work.......don't use pressure to push down on the roller. The more you push down the more paint you squeeze out to the edges of the roller leaving marks. Move quickly so you can maintain a wet edge. Load up your roller regularly and don't try to squeeze every last drop of paint out of the cover before reloading.
The Following User Says Thank You to Gymschu For This Useful Post:
user1007 (09-13-2012)
Old 09-13-2012, 03:09 PM   #4
Too Short? Cut it Again!
Again Joe?
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 13 08-01-2016 05:33 AM
Painting with a roller, what am I doing wrong? nehalem Painting 3 04-06-2012 09:27 PM
Concrete sealer roller marks the carpenter Building & Construction 2 03-21-2009 09:36 AM
Getting rid of roller marks fts123 Painting 3 09-29-2008 02:43 PM
Roller Marks - Please Help andru04499 Painting 3 09-16-2007 08:53 PM
