Roller Marks - Painting - DIY Chatroom Home Improvement Forum
Old 09-27-2007, 01:09 PM   #1
Roller Marks
Hello, I have a huge wall that I had painted by the worst painter ever. He left roller marks that are about 2 feet long where I can see. The wall is about 20 feet high. So, he did all of this a year ago and I can't stand it anymore. I want to get rid of them. The existing paint is a satin or semi-gloss with primer over new sheet rock.
Thank you
jfarringdon is offline   Reply With Quote
Old 09-27-2007, 02:10 PM   #2
mt232's Avatar
I thought I was the worst painter ever.......but I do approx. 3' x 3' squares at a time, this way, then that way....rarely see roller marks, except on darker colors, if I see roller marks thats my signal for another coat.
mt232 is offline   Reply With Quote
Old 09-27-2007, 02:22 PM   #3
Now the roller marks are about a year old. Should I sand them down first? I really don't want to paint the whole wall or I cannot paint the whole wall because of the size. Will it look like total crap if I sand, prime and paint a 2 foot by 1 foot strip?
Old 09-27-2007, 04:40 PM   #4
Rewards Points: 506
You aren't going to be able to get rid of these roller marks with touch-ups. Well-blended touch-ups are REAL tough to do to begin with, and trying to do them a year later, with new paint, and not having completely identical equipment as the original painter is going to be well-nigh impossible.
There are multiple causes of roller marks:
1) Cheap paint
2) High sheens. (They make it more likely anyway)
3) "squeezing" the paint out of the roller.
4) Cheap roller cover.
5) A roller cover of insufficient nap.
6) Covering too much wall space with each roller full.
The best ways to avoid them:
1) Quality paint from an actual paint store, instead of Big Box Inc.
2) Lower sheens. Flat or eggshell/satin is good for almost all walls.
3) Let the roller do the work and "lay" the paint on the wall. Don't squeeze paint out of the roller. (This is a REAL common mistake.)
4) Nothing cheaper than a 3/8" Purdy White Dove. 50%poly/50%wool covers from Purdy or Wooster also have a lot of fans.
5) 3/8" should be about the minimum size for walls, unless you enjoy refilling your cover every 4 sq. ft. If roller marks are still a problem, or you have really tall walls, go bigger.
6) Forget the W, M or N pattern stuff, unless you want a lot of extra exercise. I did a single floor to ceiling 8' stripe with each load of Sherwin Williams SuperPaint Satin with each 3/8" White Dove load. No roller marks at all.
If you follow these tips, you will not have to worry about roller marks at all.
SirWired
sirwired is offline   Reply With Quote
Old 09-28-2007, 06:48 AM   #5
Tired, Cold, and Damp
slickshift's Avatar
Pretty much guaranteed yeah
You could sand them a bit, if thyey are "raised" it will help
But you'll need to paint the whole wall using the directions and techniques posted by sirwired
slickshift is offline   Reply With Quote
How do you use a loop roller? redline Painting 8 04-02-2013 09:05 AM
Roller Marks - Please Help andru04499 Painting 3 09-16-2007 08:53 PM
Trail marks on hardwood floor - HELP!! Hitchcock Flooring 1 08-06-2007 09:23 PM
to spray/power roll? putri Painting 10 07-20-2006 02:34 PM
Loop Roller redline General DIY Discussions 2 03-21-2006 07:27 PM
