Roll Vs Spray On Knockdown. - Painting - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 04:37 PM   #1
roll vs spray on knockdown.
Is it safe to roll prime new knockdown texture, or should it be sprayed?
mbaker76 is offline   Reply With Quote
Old 12-04-2008, 01:03 PM   #2
Workaholic's Avatar
Rewards Points: 268
If it is fully dried then rolling it should not be a problem.
Sean
Workaholic is offline   Reply With Quote
Old 12-04-2008, 02:08 PM   #3
RippySkippy's Avatar
If you were to spray, then you should back roll. So yeah...if it is dry...you'll be fine.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 12-04-2008, 03:53 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
-Ayup
slickshift is offline   Reply With Quote
Old 12-04-2008, 03:59 PM   #5
I was told that if you roll it then I would risk softening the texture and pulling it back off the ceiling.
Old 12-04-2008, 04:02 PM   #6
Workaholic's Avatar
Rewards Points: 268
Knockdown will be fine. Now if you were talking about popcorn ceiling texture, you would want to run an oil primer over that prior to putting latex on it.
Sean
Old 12-04-2008, 04:05 PM   #7
slickshift's Avatar
If it's a good quality job,and properly dried, it won't be an issue
Your 'adviser' has a point only inasmuch as old, neverbeenpainted popcorn, can be an issue when repainting years later
K/D is not really the same animal, and again, a fresh quality job properly dried should not be an issue
Seriously, I would not give it a second thought
Spray or Roll - or contract uokman Painting 2 04-09-2008 11:09 PM
Spray and then roll Sftail2 Painting 2 03-23-2008 12:10 AM
roll or spray? chjochel Painting 9 08-24-2007 08:46 PM
to spray/power roll? putri Painting 10 07-20-2006 02:34 PM
