Roll, Then Cut? - Painting - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 08:28 PM   #1
Roll, then cut?
I've always cut in, roll, let dry then cut and roll again, done. I see guys talking about rolling, then cutting. Does this mean to roll first coat (as close to ceiling, base, casing as possible) and let it dry completely, then come back and cut in and roll on the second coat? I'm confused as to if you cut in on both coats, or just the second.
Yeti is offline   Reply With Quote
Old 01-31-2013, 08:41 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Your way is fine. With the new paints- it is also good on the first coat to roll first- cut twice and then finish roll.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-01-2013, 10:10 AM   #3
Gymschu's Avatar
Rewards Points: 1,022
Yeti, I do the same thing. It is "old school" but effective. As BJ suggests, with the new chemistry of today's paints, you can just about do it anyway that is comfortable and convenient for you. You don't get as much hat banding or holidays like you did with the old formulas.
Old 02-01-2013, 11:08 AM   #4
For the "New school" method, do you roll the first coat and let it dry completely without cutting in? Or do you still cut in twice just reversing the order of rolling and cutting? Just trying to figure out if there is a better way compared to what I've always done. And if you would choose one method over the other based on light or dark colors.
Old 02-01-2013, 12:59 PM   #5
cdaniels's Avatar
As long as it is cut in twice before the final rolled coat your good to go.Always roll it as closely as you can on the second coat.As fast as modern paint dries,it's almost impossible to roll it before your cut-in starts drying even if you do one wall at a time.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-01-2013, 06:44 PM   #6
Rewards Points: 512
i cut in a wall then roll it to cover up most of the brush marks then go to the next wall and so on. depending on the size of the room i can start the second coat when i get back around from where i started
princelake is offline   Reply With Quote
Old 02-05-2013, 07:19 AM   #7
Cut In FIRST,,, ALWAYS !
Cut in 1 wall, (if you don't have a helper) then roll into the drying cut in
I retired from Union Painting business after 30+ years and this method produces the best end result ! If you see someone rolling first it is usually because they lack the experience to KNOW what needs cut in, without first rolling. Good Luck,,, Steve
b679995 is offline   Reply With Quote
Old 02-05-2013, 07:22 AM   #8
When did you retire Steve? (Welcome to the forum BTW!)
The new acrylics, particularly the BM gennex dry so fast you don't have a chance to do that, and actually its recommended not to.
Roll, cut twice and finish roll tight is a very acceptable method.
Old 02-05-2013, 07:36 AM   #9
I actually retired from IBPAT around 10 yrs ago due to disabilitys, I still RAT a little when I can find any, I must be pretty Old School, guess I need to take a refresher course,,,, I Do like the acrylic varnish tho, I used it on a RAT project at the customers request because she couldn't deal with the smell of the real stuff,,, I Liked it,, worked good and looked good !!
Old 02-06-2013, 05:32 PM   #10
Grants Painting's Avatar
Charlie D nailed it.
Charlie is totally correct
It doesn't matter as long as the second coat roll is done last.
Last edited by Gary in WA; 02-09-2013 at 05:19 PM. Reason: removed web link per forum rules.
Grants Painting is offline   Reply With Quote
Drain pipe size for roll in shower frickell Plumbing 1 04-05-2012 08:36 PM
Vent Flashing for Low Slope Mineral Surface Roll Roofing Thumbhammer Roofing/Siding 4 05-22-2011 05:52 AM
Amana roll out switch light blinking butter99 HVAC 2 04-02-2010 10:19 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
to spray/power roll? putri Painting 10 07-20-2006 02:34 PM
