Risers - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 08:19 PM   #16
Too Short? Cut it Again!
Originally Posted by chrisn View Post
Guess who?
He also made this worthless comment in the SAME post
"Going to need a Mouse style sander to be able to get into all those corners".
AGAIN with the HORSE HOCKEY
I think I am going to have to come up with a much stronger term, any ideas?
I am sorry but I cannot participate. I have gotten out my white silk pillow and Japanese dagger and must commit sepico for having used flat paint that shows handprints and cannot be washed. I have brought great shame to my clients over many years.
Old 02-26-2012, 05:30 AM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Well, tht's probably the right thing to do for using cheap paint from HD and Lowes
Old 02-26-2012, 01:34 PM   #18
Alas I failed. As you know, I bought the cheap---but authentic looking--- dagger at a box store. They are my fave places to shop. I could have done more damage with a tape measure from such a place.
I must have hit a rib on the upward cut. The cheap Chinese rivots in the plastic handle popped and I could not hold on to the 1/2" thick piece of steel to complete the sacred cuts. Next time I will wear cheap Chinese work gloves.
Old 02-26-2012, 01:47 PM   #19
And Bag-O-Brushes 20 for $5?
And 1/4" foam rollers 100 for $2?
I like them because you don't have to even think of caring for them. Use them and forget them. They are cheap enough if you leave one out for hours and it turns all crusty and nasty you just grab another one.
Oh well. Was thinking of making layered salmon for dinner. Only place to get it fresh is at Lowe's, Menard's or HD right? If they sell paint, they may even have softshell crabs in season? Makes as much sense as them claiming to sell real paint.
Old 02-26-2012, 05:27 PM   #20
chrisn's Avatar
Rewards Points: 120
You layer the salmon with softshells?
Sorry about the sword thing, now you know
Old 02-27-2012, 12:54 PM   #21
The New Guy
Ok this is what I have so far, Brushes, the spackle which was recommended, Behr Paint & Primer (white), painters tape, and sandpaper. I am attaching pictures before I start because I don't want to screw this up. My question is, should I use the angled brushes for the whole project or should I use a roller, 4" + brushes, or common sense?
Needsassitance is offline   Reply With Quote
Old 02-27-2012, 01:12 PM   #22
Rubbin walls since'79
Brushjockey's Avatar
You could use the rollers- but each riser is such a small area I would just use the brush. The roller would be just to get it on faster- should be laid off with the brush ( Long way- as if with the grain) either way.
I would also go with a higher sheen than flat- satin on trim is pretty standard.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Needsassitance (02-27-2012)
Old 02-27-2012, 03:05 PM   #23
Take the paint back and get something other than BEHR. And know there is no such thing as paint and primer in one.
Old 02-27-2012, 04:57 PM   #24
Sds- I really feel that blanket statements are really hard for someone not familiar to grasp. There ARE situations that it is true- but just not for all that a primer would be needed. I don't like the box paint either- but it's out there and we have to educate- not just throw pies at it.
Throw this link from JS in your bag of tricks and bring it out for situations like this.
http://buildipedia.com/at-home/painting/paint-vs-primer
He went through the effort to make it, might as well use it.
Alot of advice givin here is a little knee jerky- help people to "get it".
JMO- not really busting your chops- just upping your game!
jsheridan (02-27-2012)
Old 02-27-2012, 05:44 PM   #25
chrisn's Avatar
Rewards Points: 120
Well, foe sure take the flat back and get at least satin, semi gloss would be better yet. I will not comment on the Behr.
I lied
Stair Tread and Risers tuchodi Flooring 0 08-03-2011 09:38 AM
Precast seps and risers DETROIT GRIFF Building & Construction 3 04-12-2011 10:06 PM
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 09:32 PM
Tiling Step Risers ironmanDIY Tiling, ceramics, marble 1 03-09-2009 11:01 AM
Staining treads, painting risers QueenL Building & Construction 5 04-13-2008 10:23 PM
