Old 01-28-2008, 05:24 PM   #1
Stretch
Default Retexturing / Priming walls...
Our fixer-upper homes' walls have three different textures...as we move thru the home with a complete remodel, we want to retexture the walls for uniformity.
To retexture, I plan on doing all the prep myself, then have a professional drywaller come in and apply the retexture itself. My understanding is to apply drywall mud to the walls to make it a smooth surface again, then let the drywaller dude do his thing. The style of texture we will have applied is called tuscan, I believe...where it is applied like frosting a cake...that rough, adobe look.
Should I prime the walls before each layer of mud is applied. Does primer increase the adhesiveness of the next layer of mud, or am I wasting time & effort...Basically I would prime the walls, apply mud to smooth, apply primer again, retexture, apply primer again, then paint.
Thanks in advance!
Stretch
scheenstra is offline   Reply With Quote
Old 01-28-2008, 07:41 PM   #2
Pro Painter
The only primer step will be after the new texture is applied, just before painting.
The other 2 steps you mentioned are not necessary and are not done by pro drywaller/tapers.
joewho is offline   Reply With Quote
Old 01-28-2008, 09:15 PM   #3
Stretch
Thanks, joewho...that will save me a bunch of time/effort/$$$...
Stretch
Old 01-28-2008, 09:29 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
If the surface now has paint, especially with a sheen on it or of questionable condition/quality, then it should be primed first before applying a finish such as this
Technically, even new/bare sheetrock should be primed, but usually this step is skipped by the texture people
The best plan is to contact who ever will be doing the texture, and have them 'spec' it for you
They may have specific preparations that they prefer
Such as prime/no-prime, primer/sealer, brand/type...
It will make the project go much smoother and faster...and cheaper for you, and the tradesman will appreciate that you asked and did the prep to their 'specs'
slickshift is offline   Reply With Quote
More On This Topic
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
The next step in painting a living room is going to be priming the areas that we repaired. You are going to need a brush, obviously; and I recommend using one of these little hot dog, as they call them, roller. We got our primer here, just going to give... Read More »
Now for eyelids. I like to prime the eyelid with a eyelid primer I love the Channel eyelid primer cause it is water proof, increase proof. I like to move from the lower lid to right underneath of the eyebrow to opening up the eye with a neutral color... Read More »
Hi! This is John on behalf of Expert Village in this video clip I will be talking about preparing for paint. Now that we have finished priming our walls we are almost ready to put paint on, there is just a couple of things that we need to do first. What... Read More »
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 05:07 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 10:39 AM
Moisture on walls chrisr Building & Construction 1 01-20-2008 11:37 AM
help! my walls are troubled donnamarie General Discussion 5 08-29-2007 02:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
