results for diy concrete stains?
Clean the concrete using a per carbonate. Wash safe sells a great concrete cleaner. You need to use a nylon brush to brush the cleaner around and then let it sit for about ten minutes. Use your power washer to rinse it off moving the wand in even strokes holding it the same distance across the concrete. Improper cleaners and improper power washing results in zebra stripping which is what you described during your cleaning process. If you have any smooth areas of concrete apply an etcher to roughen the surface. H&C makes good concrete stains, including transparent, solid, and acid. After applying your stain apply a clear over it. The clear will enhance it and help it to last longer.
