Restore Vs. Olympic To Seal My Wood Deck - Painting - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 07:22 PM   #1
Restore vs. Olympic to seal my wood deck
I have narrowed it down to restore and Olympic to seal my deck. I live in south eastern indiana so cold winters and hot summers. The deck it almost 20 years old and the only product used on it is flood sealer.
Anyone have any luck with these brands?
Is there a better brand out there for my needs?
Any and all feed back is very welcome
Thanks,
Mark
Mydogezra13 is offline   Reply With Quote
Old 09-15-2013, 08:40 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
Well, I don't think anybody has much long term field data on these two yet. They are fairly new, and exciting products, that will be really sweet if they perform as advertised.
I used the Olympic Version, Rescue recently, and jeffnc did a good review on the Restore
The Restore is definitely the more heavy duty of the two. The film goes on twice as thick. So, how bad the wood is split/cracked might be a consideration. The restore will bridge bigger cracks presumably.
I liked the Rescue. Got one coat on my little back porch. It filled the smaller cracks, and partially filled the rest of them. Seems very tough, and like it bonded well.
Jmayspaint is offline   Reply With Quote
Old 09-15-2013, 09:02 PM   #3
Rewards Points: 4,796
Restore thread here
Rustoleum Restore project
As jmays says, the Restore is the heavier duty one. Go with Rescue if you want it a little thinner - more paint like - smaller crack filling. Go with Restore if you want it thicker and more concretey - bigger crack filling.
jeffnc is offline   Reply With Quote
Old 09-15-2013, 09:44 PM   #4
Thanks so much for the information... I was leaning towards the Olympic maximum..... Is there muc difference between that and the rescue ? Is the rescue thin or thick?
Old 09-15-2013, 09:45 PM   #5
Originally Posted by jeffnc View Post
Restore thread here
Old 09-15-2013, 09:49 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
Oh... Ok sorry. When you mentioned the Olympic along with Restore I assumed you were talking about the Olympic product in the same category, the Rescue.
Olympic Max is a whole different kind of product....
Old 09-15-2013, 10:08 PM   #7
Rewards Points: 14,026
A 20 year old deck is about 5 years behold it's expected life span.
With no pictures it's hard to tell if it's not time for a totally replacement.
My biggest fear with all these new deck coatings is people coating unsafe decks just to save money.
robertcdf (09-25-2013)
Old 09-15-2013, 10:10 PM   #8
That's a good point. Before coating, the deck should be carefully evaluated, and anything needing replacement for structural reasons should be done first.
Old 09-23-2013, 02:19 PM   #9
Rewards Points: 590
My deck is at least 15 years old, and while I've been busy replacing a lot of deteriorated cedar planks the substructure is rock solid. Even if I got someone to replace just the planks (and railing), that would be a pretty big expense.
Funny, but the original steps are still in great shape. This thing would probably just need a few patches here and there if they'd spaced the boards at least 1/8" so debris didn't pack in there and hold water.
operagost is offline   Reply With Quote
Old 09-25-2013, 06:28 AM   #10
robertcdf's Avatar
Joe nailed it.
These kind of products will lead to water logged decking and framing that will shorten their lifespan, however it won't be apparent to most inexperienced people until it fails.
robertcdf is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Replacing Deck - Can I seal the wood first? mdawson3k General DIY Discussions 4 06-27-2011 10:43 AM
Epoxy or Resin Paints for Outdoor Wood Deck CruiseDivaNJ Painting 21 04-16-2011 04:58 PM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 12:38 PM
