Restaining Front Porch - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 03:37 PM   #1
Hvac pro
Rewards Points: 41
restaining front porch
I have a tounge and groove front porch which was put in and stained about 4 years ago right before I bought my house . I failed to reseal it and shows fading from water and mostly the sun in some spots. I tried taking the same color stain and applied it in a few spots and it soaked it right up nicely. Can I just power wash it and stain it since I took the new stain so well rather than sanding it?
aa7483 is offline   Reply With Quote
Old 04-03-2014, 04:59 PM   #2
Rewards Points: 13,456
I'd use a brightener to clean it up then just restain it unless it's in really bad shape or the pressure wash was to aggressive and left a bunch of burrs.
No need to sand off the old stain.
aa7483 (04-04-2014)
Old 04-03-2014, 05:39 PM   #3
Hvac pro
Rewards Points: 41
Awesome. Only other thing . They stained with a regular min wax stain. I was just going to go back over it with the same. Is it ok to just go over it with an outdoor sealer after that?
Old 04-03-2014, 07:19 PM   #4
Gymschu's Avatar
Rewards Points: 662
No need for a sealer after staining.
Also, Minwax is an interior stain. I would look into something like Deckscapes from Sherwin-Williams for an exterior wood deck.
The Following User Says Thank You to Gymschu For This Useful Post:
aa7483 (04-04-2014)
Old 04-03-2014, 07:47 PM   #5
Hvac pro
Rewards Points: 41
I was thinking that but the majority of the wood hasn't been faded too badly so wont I have an issue with color if I go with a different stain?
Old 04-03-2014, 08:03 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
Does it have a sealer on it now?
Jmayspaint is offline   Reply With Quote
Old 04-03-2014, 08:22 PM   #7
Hvac pro
Rewards Points: 41
I don't think so given how easily it took stain. I also found a can of mcclosky storm coat in the basement. Wonder if that's what they used. I'll have to put some of that on there to compare color. WIsh I hadn't put a big blotch of the min wax on there now. Guess I can sand that spot a little.
Old 04-03-2014, 08:42 PM   #8
Gymschu's Avatar
Rewards Points: 662
By all means, use what was successful. I would say that if your only problem is a bit of fading, then, perhaps the Minwax is working in your situation.
Old 04-03-2014, 08:52 PM   #9
Hvac pro
Rewards Points: 41
Well now that I found that can of exterior that may be what they had on there . I don't have any other wood outside. I'm gonna test a small spot tomorrow. Now that I think about it the minwax did seem a bit dark
I figured it had just faded. I'll just have to sand the test spot and hope it all comes
together.
Help! Need a Non-Slip Front Porch Surface phillips_sl Flooring 2 10-25-2012 08:27 AM
Operation Front Porch = Outdoor room Complete! Leah Frances Project Showcase 14 04-27-2011 09:14 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
Building a front porch and have questions... SolidStateS15 Building & Construction 9 07-10-2010 04:16 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
