Restaining Banister - Painting - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 12:37 PM   #1
Restaining banister
Planning in restaining newels & handrails a darker color. Is there a stripping product you would recommend to use before sanding? I think the old stain & poly are water based. I assume a different product if oil based?
stan 41943 is offline   Reply With Quote
Old 06-12-2008, 07:03 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Are the pieces removed for stripping?
slickshift is offline   Reply With Quote
Old 06-12-2008, 08:25 PM   #3
My problem is that if I try to remove the newels & handrails I'll damage them & then need to replace them, so thought first I'd try to strip, sand & refinish. The present stain is in fact oil base.
Old 06-13-2008, 05:12 AM   #4
slickshift's Avatar
As local regs and product availability differ, I'd recommend going to a real paint store (not a chain hardware store or big box home center) and ask for the best stripper available in your area for your specific project
With a little luck they may have something that works well fr you application
I feel I must warn you that even if they have something that works it will be messy, stinky, and time consuming
And leave you with a lovely large blob of hazardous waste to get rid of
...and you still might need a fair amount of mechanical removal (sanding)
...and that's the "Best Case"
Not that you shouldn't do it...just a Heads Up
Old 06-13-2008, 08:09 AM   #5
Thanks Slick. I'm TRYING to talk the wife out of changing stain color.
restaining deck, new/old wood... Mr. Michael Painting 11 11-19-2012 12:35 AM
Restaining handrails stan 41943 Remodeling 3 06-01-2008 06:45 PM
Finishing wood banister digexpressions Painting 1 05-17-2008 09:20 AM
stair banister on a weight bearing wall angelwill26 Remodeling 1 03-09-2008 07:13 PM
restaining cherry cabinets royal rooter Painting 1 03-08-2008 12:46 AM
